Not cranking. - Defender Source
Old December 22nd, 2012, 11:06 PM
bjp
Brent
1995 D90
Not cranking.
Hate to start a new thread but went to start the truck it fired right up, but then I turned it right off as I forgot to unlike the tuffy. Went to start it back up and not cranking. All lights come on, fuel pump running, but will not crank. Not a juice problem. Any thoughts. I left it in the parking garage, no idea how Im going to have it towed out of there. Low ceiling on level 4. No burning smell or other symptoms. Has been running fine.
------ Follow up post added December 22nd, 2012 08:08 PM ------
To make things worse I almost lost it. At least 20 people asked if I was leaving as they waited for my spot, even though the hood was up and I had the steering column apart.
Old December 22nd, 2012, 11:13 PM
Get underneath and bang the starter with something, then try it again.
Old December 22nd, 2012, 11:42 PM
lbowers
L Bowers
1997 D-90: ST, BRG
I had a very similar issue. I have a 97 ST. I drove to a gas station, shut it off and then could not get it going again. Turned out to be a fuse for the starter that kept blowing because I had the third brake disconnected. I have no idea why having the brake lights disconnected would prevent an off-road vehicle from starting but... After I reconnected the third brake light and switched out the fuse it started right up and I have had no issues. I would check the fuses, but you have probably already done that. Good luck. A broken rover in the middle of the night away from your garage is never fun.
Old December 23rd, 2012, 09:48 AM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Bad distributor cap & rotor button.
Weldon
Old December 23rd, 2012, 10:23 AM
Wouldn't it still crank with a bad cap & rotor?
Old December 23rd, 2012, 09:00 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Yeah. Wouldn't affect cranking.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old December 23rd, 2012, 10:30 PM
dbj2003
Brandon Jones
94 Defender 90 POE
loose wire to the coil?
Old December 23rd, 2012, 10:42 PM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
i would check fuses, give the starter a nice few hits with something, and try it again.
Old December 24th, 2012, 10:31 AM
Antichrist's Avatar
Antichrist
Tom Rowe
That wouldn't affect cranking.
Only things in either the low amp starter circuit or high amp starter circuit would cause slow or no cranking.
OP, make sure the battery to starter circuit is solid, including the earth points, then jumper from the solenoid spade connector to the main feed from the battery. If it cranks then it's somewhere in the starter part of your ignition switch circuit.
If it doesn't crank it's the solenoid or starter motor. Final try to get it home is a jumper cable on the main stud (on the motor itself, not the solenoid) the other end of the cable to the pos battery post. If it doesn't crank then, and whacking the starter doesn't help, it's tow truck (or field replacment) time.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old December 24th, 2012, 10:58 AM
Auto or manual? If manual push start it.
Old December 24th, 2012, 11:50 AM
bjp
Brent
1995 D90
Checked all fuses, hit starter with hammer, all connections were fine, dis cap, new wires and s plugs 1 month old. Gave up pushed car out of parking garage and towed. My guess starter motor or ignition cap. Will find out. Thx for the thoughts. Fa la la la la la la fcking la.
Old December 24th, 2012, 01:37 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Cap, rotor, spark plugs, etc. have nothing to do with cranking.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Hand cranking a V8 ini88 Misc. Chit-Chat 3 July 25th, 2011 05:23 PM
Not starting '95 what to check next. jcasteel Defender Technical Discussions 17 June 10th, 2005 02:38 PM
CAn't get my defender to start tmore Defender Technical Discussions 4 May 21st, 2005 07:12 PM
Hard starting, everything else fine? Doug Defender Technical Discussions 16 July 11th, 2004 01:25 PM
