Not a fan of oem - Defender Source
Old August 30th, 2016, 01:17 PM
Not a fan of oem
Just venting. Sometime's you cannot pay for a quality part for these trucks. Attached is a picture of a tdi valve cover and an oem valve cover gasket and the bag it came in. Its not even remotely close to fitting. These fit into a groove in the valve cover and when you stretch it one place to get it to fit of course it lifts out elsewhere. I tried gluing it into the groove with silicone but the ability to put spring clamps on it to hold it as you work your way around is nill.
The gasket dimension's vs the actual casting is off considerably with none of the curves etc matching up. It shouldn't take hours just to change a gasket. Placed the cover back on without a gasket and rolled the truck out of the way. Going to have to order in an aftermarket gasket.
Old August 30th, 2016, 01:37 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
That looks awful
BTW never ever use silicone to stick a rubber gasket to metal. Weatherstripping adhesive works much better as it is designed as a contact adhesive for rubber to metal.
Sent from my SAMSUNG-SM-N920A using Tapatalk
Old October 19th, 2016, 08:28 PM
phunter
phunter
1993 NAS 110
valve cover gasket
wondering wh0 the best manufacturer is for valve cover gaskets for 95 rrc. where to order? what adhesive is recommended? anyone recommend gasket maker in addition to gasket?
thanks for any and all replies.
fan, oem
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 08:10 PM
Size of fan bolts on viscous fan clutch imeek Defender Technical Discussions 4 September 26th, 2009 02:12 PM
Flex Fan (Clutchless Fan) NashvilleRedD90 Defender Technical Discussions 3 June 12th, 2005 02:09 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 05:19 AM
D90 -- Fan clutch and fan Vadim Wanted 3 August 1st, 2004 12:00 PM
