Normal T-case driveline slack? - Defender Source
Old May 24th, 2014, 11:02 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
So for the past 2 days I accomplished one of my life goals to drive the Rubicon Trail. Amazing trail but naturally, it took it's toll on the D90. Tore off a shock mount, bent a bilstien 7100 in half and snapped 3 axles. More specifically, broke the driver rear almost in the middle of the shaft, and grenaded both front CVs. Long story short, truck made it to the Tahoe parking lot on just the passenger rear shaft. I drove it back to San Francisco like that with the Tcase locked and the rear locker on.
Got everything apart and I was under there and noticed a lot of gear lash btw the front and rear shaft with the center lock engaged. Took a measuring tape to it and I can rotate the front shaft 1-3/4 inch before the rear will turn. Is that normal or a sign of something about to let go? Driving home there was considerable clunk in the driveline when I let the clutch up but I attribute that to having just one axle in the system. The T-case has probably 2K miles on it since it was rebuilt with GBR reduction gears. So is it normal or no?
Old July 14th, 2014, 04:52 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Thought I'd follow up here in case anyone else searches for this one day. After testing this against another defender, both trucks had roughly an 1/8 rotation of the driveshaft independent of the other shaft with the diff lock on. The test I did had both cars on jack stands. diff lock on, trans in neutral, and the parking brake applied so the rear shaft wouldn't move. Manually rotating the front shaft I got about an 1/8 of a rotation before the gears locked up.
Old July 14th, 2014, 08:22 PM
i can push my range rover about 4" in park
ac
Slack in Timing Chain 61rover Defender Technical Discussions 3 July 26th, 2011 10:20 PM
Wiper slack dnp Defender Technical Discussions 3 May 12th, 2007 08:14 PM
Rear Pinion slack flippedrover Defender Technical Discussions 4 September 12th, 2005 10:07 PM
Sean Slack chrisvonc Defender Owners 0 February 24th, 2004 10:38 PM
Driveline Clunk in early '94 D90 Hans Defender Technical Discussions 8 November 25th, 2003 09:43 PM
