Normal operating coolant/oil temps for 300tdi? - Defender Source
Old September 24th, 2017, 06:43 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
1988 D110 300tdi/R380
Hi all,
Took my project for the first spin around the block in 2.5 years. This was the first time it's ever been driven with the new powerplant besides being loaded on/off the trailer for paint.
Observations:
Coolant temps seem to operate around 185F when cruising 30-40mph. Oil temperatures were ~20F higher. Is that normal?
I've searched, searched, and searched and can't find what's "normal" for the 300tdi. I'm using the top of the thermostat housing for the coolant measurement point, and an oil sandwich filter for the oil temp/pressure measurement point.
Thanks for your input!
Old September 24th, 2017, 07:54 PM
I have a 200tdi, but I figure the two engines aren't that much different.
Coolant temp sounds correct. Despite having way too many gauges on my truck, I do not have an oil temp gauge.
Do you have an oil pressure gauge? It should be around 60psi cold and about 18psi hot on 15W40.
Old September 24th, 2017, 08:13 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
Oil pressure looked normal. (It's part of the Madman gauge package). Was high of 45psi after warming up and maybe 20 at idle?
Old September 26th, 2017, 05:20 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
Bump for more feedback. Does anyone else have a working (digital) oil temp gauge on their 300tdi setup?
Old September 26th, 2017, 05:43 PM
Temperatures are normal. I hope the coolant gauge is before and not after the thermostat.
Old September 26th, 2017, 05:48 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
Coolant gauge is reading from a plug that replaces the fill plug on top of the housing, eg:
Oil temp being measured off of a sandwich plate mounted to the OEM oil filter location.
Old September 26th, 2017, 06:28 PM
That location is fine.
Old September 26th, 2017, 08:08 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
Any thoughts on the sandwich filter/oil temps?
Old September 26th, 2017, 09:07 PM
It should be fine. Just make sure it does not interfere with the oil cooler flow. It is such a pain that they removed the oil temperature sender port on the 300TDIs.
300tdi, coolant, tdi
1989 rrc normal running temps? 1962siia88 Defender Technical Discussions 3 April 26th, 2012 02:50 PM
Normal Running Temps aaronlam Defender Technical Discussions 11 January 6th, 2012 10:09 AM
Heat temps very low 1of40 Defender Technical Discussions 9 February 15th, 2006 03:39 PM
Engine Temp - Normal range mgrgpg Defender Technical Discussions 5 June 10th, 2004 07:47 PM
D90s Operating in Today's Pakistani Offensive wicks Misc. Chit-Chat 4 March 18th, 2004 07:14 PM
