Normal Compression Test reading - Defender Source
Old January 30th, 2013, 12:02 PM
wantone
Rick Thompson
94 ST #1222
hi gents! i am changing out my plugs and wires soon and figure while i am at it i may as well hook up the compression tester and test each cylinder and do a leakdown. What are the normal readings for compression and what is acceptable for leakdown and for how long of a time?
thanks!
Old January 30th, 2013, 12:05 PM
High 140's. Not sure on leak down
Old January 30th, 2013, 12:23 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Just curious, if you have good compression why would you do a leak down test?
Old January 30th, 2013, 02:14 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
20% is acceptable , i would be more concerned where its leaking from top end or bottom end
how does the truck run does it idle good have power any engine codes missfires?
No Mall crawler here
Old January 30th, 2013, 02:52 PM
wantone
Rick Thompson
94 ST #1222
Truck runs fine. Has 150k on it, i have the tool & will be changing the plugs so why not check it? How long should i do the leakdown for? 5 min? 20 ?
Old January 30th, 2013, 03:06 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
Usually with the proper tool it's a instantaneous reading example 80psi on in gauge to anything above 20psi on the leak down side gauge .. Make sure your on the compression stroke of the cylinder your doing. I usually do a compression and leak down on a motor that’s at operation temp then another leak down when cold just to make sure . Also you might have to hold the crank from spinning if you put too much air in it
Temperature Gague false reading trick? arbik Defender Technical Discussions 67 April 30th, 2017 09:45 PM
Test Drive- Normal Driving Characteristics?? ZGMatt Defender Technical Discussions 9 April 12th, 2009 12:43 AM
Distributer air gap ScottYates Defender Technical Discussions 7 December 15th, 2006 02:46 PM
Compression Test Results... need help interpreting them martym Defender Technical Discussions 12 March 3rd, 2005 09:46 PM
Dreaded Emissions Test and P1317- ABS Rough Road d90xj Defender Technical Discussions 3 October 24th, 2004 01:23 PM
