Non D90 Technical Question jump start polarity problem - Defender Source
Old September 4th, 2004, 02:16 AM
dnewman9's Avatar
dnewman9
Dennis Newman
*SOLD*Conniston 97 NAS 90
Was at a car lot tonight looking to replace my wifes minivan and the one we were looking at would not start.
The sales guy went and got one of the battery packs to jump it and while I was inside the car looking it over he hooked it up. He flipped the toggle switch and all the lights on inside went off and came back on in the vehicle. He did it again and no start. I tried to start it a couple times, got the solenoid click, before I got out of the car and looked at what he was doing and sure enough he had the polarity reversed on the cables. At that point he had the pack shut off and I quickly disconnected the thing.
I then reconnected it back the correct way and it started right up. The vehicle was a Town and Country mini van with power(electronic) everything.
I would like to go back tomorrow to buy it but I am concerned about the long term affects of what he did? I checked all the gadgets I could and it all appeared to be fine. I would hope that Chrysler was smart enough to protect against that but am not sure. I have to beleive the battery took a beating and will need to be replaced at a minimum but am not sure.
Anyone have any advice as to what I should look for?
Dennis
Sorry for the non-d90 topic, i just wasn't sure where else I could go with equal expertise as here? If this should be moved sorry and thanks.
Old September 4th, 2004, 12:00 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Dennis I don't have any info for you on this subject but I noticed the picture of your Def and it looks identical to the one I bought about a year ago. Is that picture your current Def?
Old September 5th, 2004, 01:53 AM
dnewman9's Avatar
dnewman9
Dennis Newman
Yea, this is my truck, i got it off ebay back in December. Bought it out of Missoula Montanna.
Dennis
Old September 5th, 2004, 08:31 PM
The most he would have done is drained the batteries some, if the engine starts then the ECM is fine. When you put to batteries together like that they short each other out, and over time they would have droped 0 volts. So when he hooked it up the voltage droped most likly. I would say that you should try and get a new battery for it. But I have to tell you I HATE minivans!
Old September 6th, 2004, 05:39 AM
BarryO
Barry O'Mahony
97 D-90 SW LE
Any engineer that does not design to protect against this doesn't deserve his/her job. So yea, the factory equipment should be OK. Check any aftermarket electronics carefully.
90, d90, start
D90 Jump Seats ddrotts For Sale - Parts 14 August 14th, 2009 02:48 PM
3.9 RR to 3.9 D90 question BECFA Defender Technical Discussions 1 March 17th, 2008 07:50 PM
Non D90 tech question... Wobble while braking. jabber Defender Technical Discussions 5 August 30th, 2005 09:22 PM
Need Help: Odometer Question WCURoverD90 Defender Technical Discussions 6 August 5th, 2005 07:41 PM
