Noisy Transfer Case - Need Advise - Defender Source
Old February 1st, 2008, 01:19 PM
Yeah, my transfer case was kinda noisy, so I pulled the cover and took a look - can someone tell me if this is an excessive amount of metal shavings?
Old February 1st, 2008, 01:25 PM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
isn't that normal in a defender?
Old February 1st, 2008, 01:27 PM
Eddie 1's Avatar
Eddie 1
EDWARD BAHAW
Disco 1 TDI 300 SE
That does not look normal!
Old February 1st, 2008, 01:28 PM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
ha. that's rough.
because six cylinders will take us farther than any president
Old February 1st, 2008, 01:29 PM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
Jim - I've always heard that a small amount of metal shavings is fine, so I'll say you're good to go!
Oh, I forgot that we needed to add 's to our posts this week to express sarcasm!
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old February 1st, 2008, 01:37 PM
Emerson00
Matt J.
None at the moment
Post No. 1 in this thread looks like something I'd have posted myself...
Dayum that's a picture.
Old February 1st, 2008, 01:54 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
you're fine, its basically like Teflon.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old February 1st, 2008, 03:46 PM
CDN22's Avatar
CDN22
Ken
1994 D90
A little Redline will clear that up in no time...
Old February 1st, 2008, 04:01 PM
headdamage's Avatar
headdamage
Andrew
exmod 90 2.5na and a 93/RRC 200tdi
WTF happened to that?
Old February 1st, 2008, 04:23 PM
Talking
Jim, is that really your truck? Did Ron pack that full of saw-dust to keep it quite before he sold it to you?
Old February 1st, 2008, 04:38 PM
Its actually the yellow truck that suffered this catastrophe. The transfer case decided to detonate for some reason. Interestingly, there is also some fairly ominous looking sludge in input area. Unfortunately, as the t-case died its death, it too the trans with it, as you can see by the dramatic spline wear on the output shaft. It must have been going bad for a while, but it got very regular oil changes.
Sadly, all I could do from overseas was phone with the credit card details. FYI, having a trans and t-case replaced is costly when youre being billed by the hour. The bright side is that JE Robison service took care of everything, and they were efficient and professional. I feel it was worth the 120 mile tow to have them work on it.
One recommendation though - pull your inspection cover and check the input gear every few thousand miles just for health. If I had looked sooner, maybe I would have noticed the bad bearings on the input gear before they were able to cause the spline wear that ruined the trans. That sort of problem is a huge waste of a perfectly good transmission.
Name:	C1 - Resized.jpg
ID:	12003   Click image for larger version
Name:	C2 - Resized.jpg
Name:	C3 - Resized.jpg
ID:	12005   Click image for larger version
Name:	C5 - Resized.jpg
Old February 1st, 2008, 05:13 PM
Grover's Avatar
Grover
I think a large magent on the inspection plate would help!
BTW, that would make an excellent Avatar!
Old February 1st, 2008, 05:48 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I fear I may be in the same boat... After seeing this I'm pulling the plate tonight.
Thank you for the images Jim. It is a real bummer the out put shaft was damaged.
Old February 1st, 2008, 05:58 PM
You mean the transfer case you knew was going bad and spewing oil all over the place for the last 2 plus years?
Come on JimC . . . tell the whole story.
Old February 1st, 2008, 06:05 PM
D90user's Avatar
D90user
steve
Jim,
For my information... What kind of noise and for how long was it making it before this?
Was there metal (mor than normal) in your oil previous to failure??
Cheers
Old February 1st, 2008, 06:49 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Was that a Legs rebuilt transfer case?
legend in my own mind
Old February 1st, 2008, 06:56 PM
Being a cheap bastard I would have just used a 3in input LT230 and run the trans as is.
Old February 1st, 2008, 11:02 PM
I dont think it was Legs, I thought it was Whitehouse. Nevertheless, its never been a good case. Like Ron said, its always been noisy and spewing oil everywhere and is responsible for the underside of my truck looking like a natural disaster area. I'm surprised I havent found oil soaked sea birds up under there. The reason it always got frequent oil changes is that I always had to add oil.
Old February 3rd, 2008, 04:09 PM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
That picture is so shockingly bad it could form the basis for one those forwarded-email spread urban legends.
"Uhh...I think they all leak like that."
transfer case
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
94 transfer case problems Campbell Defender Technical Discussions 25 March 19th, 2005 12:09 PM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
