Noisy bits... - Defender Source
Old September 11th, 2014, 01:39 PM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
Noisy bits...
Okay, this is getting oldÖ
Iíve got the new Turner 4.6 in the 1997 NAS D90.
The only thing from the old engine is the timing cover.
Itís still noisy.
Yes, I looked inside...the gears were gouged on the front parallel side away from the retaining plate - not the pumping faces - the housing has some marks in it, so I put new gears in the old housing...yes, clearance was within spec.
The timing cover that Turnerís sent was for a later 4.0 / 4.6 that has the oil pick-up tube attached to the back side of the front cover.
Frida says they can't supply the front cover that I need.
The NAS í97 still has the pick up on the block main bearing web, BUT obviously doesn't have a distributor and DOES have a crank driven oil pump.
Who has a good used or new (hah) front / timing cover lying about?
Old September 11th, 2014, 02:02 PM
jafir's Avatar
jafir
Jafir Elkurd
Should be the same as for a GEMS disco, 1996-1999. ERR6126 or ERR6815
Old September 11th, 2014, 02:44 PM
UnfrozenCaveman
Keith Armstrong
Various
Yessir....which seem to be NLA from the usual suspects, er, suppliers
for example... http://www.bputah.com/Parts/land_ran...ront_cover.htm
all listings followed by NLA
Old September 11th, 2014, 02:54 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
What kind of noise?
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old September 11th, 2014, 03:02 PM
UnfrozenCaveman
Keith Armstrong
Various
The kind that was there before I replaced the engine ... all except the front cover
Almost a lifter / rocker noise but not coming from up on the valve train.
Old September 11th, 2014, 03:06 PM
You sure it is the engine then? Clutch? Gearbox?
Old September 11th, 2014, 03:25 PM
Roadsiderob
Robert Dassler
1994 D90
The 4.6 crank will hit the inside of the oil pan at the front. Look for a shiny spot inside the pan. I heat the pan with a torch and use a hammer and a block of wood to stretch the metal and give it clearance. I also have a used GEMS D90/D1 timing cover if you really need one.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old September 11th, 2014, 05:10 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Why not just use an aluminum oil pan from a BOSCH engine?
Old September 11th, 2014, 05:24 PM
Roadsiderob
Robert Dassler
1994 D90
Because it has 17 bolts due to the extra bolt in the Bosch timing cover that was redesigned to make room for the oil pickup. The 1997 D90 needs a 16 bolt pan.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old September 11th, 2014, 07:08 PM
crown14's Avatar
crown14
Verticalscrote
He said he has that style front cover? Or am I reading it wrong?
Old September 11th, 2014, 07:35 PM
Roadsiderob
Robert Dassler
1994 D90
I think you're reading it wrong.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old September 11th, 2014, 07:52 PM
crown14's Avatar
crown14
Verticalscrote
Originally Posted by UnfrozenCaveman View Post
The timing cover that Turnerís sent was for a later 4.0 / 4.6 that has the oil pick-up tube attached to the back side of the front ...
Reading it again...
I think he just needs a bosch pickup, oring, and oil pan?
And one more bolt I guess
(actually I think it's a stud and nut)
Oil cooler line ends are a little different but in the short term he could run with bosch block off plugs? I would assume he would keep the Gems cam sensor.
I've not done this personally but have heard it has been done... so I could be wong
Old September 11th, 2014, 08:24 PM
UnfrozenCaveman
Keith Armstrong
Various
Rob is correct.
1997 NAS D90...came with a 4.0 & automatic.
I'll have a look inside the pan...it'll have to come off anyway to get that frontncover off and have another look in there.
Screwtechnology...I'm bringing the 80" to Utah
------ Follow up post added September 11th, 2014 07:28 PM ------
I really think the issue is with the oil pump.
I'll have another look at it...since ERR6814 seems to be NLA I'd be thrilled to find a better solution than swapping to the cast pan and associated bits.
Old September 11th, 2014, 08:33 PM
Roadsiderob
Robert Dassler
1994 D90
I have a good front cover if you need one...but I think your crank counterweight is hitting your oil pan. I remember the first 4.6 swap I did....I was super pissed that the brand new 4.6 had a knock.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old September 11th, 2014, 08:56 PM
UnfrozenCaveman
Keith Armstrong
Various
Thanks Rob. I'll have a look tomorrow or Saturday.
D-90 Noisy Brakes JKC Defender Technical Discussions 4 November 10th, 2010 10:10 PM
Damn, my driveline is noisy! JimC Defender Technical Discussions 4 November 29th, 2009 02:07 PM
Noisy Clutch bjf Defender Technical Discussions 3 September 30th, 2009 01:11 PM
Noisy Transfer Case - Need Advise JimC Defender Technical Discussions 18 February 3rd, 2008 04:09 PM
Another one bits the dust Mike Hippert Misc. Chit-Chat 29 November 23rd, 2005 07:22 PM
