Noise from engine--curse of my existence - Page 2 - Defender Source
Old June 22nd, 2005, 02:58 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I will snap a pic and post it. Did you use a keeper at all?
Old June 22nd, 2005, 03:32 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Chris,
No, the early engines with the external oil pump did not need a keeper...the pressure from the oil pump drive through the distributor gear was sufficient to keep the camshaft lightly pressed against the engine block. The cam retainer was introduced with the crankshaft driven oil pump as it is required to keep the cam in contact with the front face of the engine block. There were 2 styles, the crescent shaped one and the full circle style that bolt on over the machined lip on the cam nose to keep it in place. I have a 900531 here in the scrap pile (oil pump quit, lost 2 lobes and cam bearings, hence the rebuild) and it is not machined to take a cam retainer. That's why I'm curious as to how you were able to use the retainer. Rob
Old June 22nd, 2005, 05:07 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I had a buddy at a machine shop mill the cam to accept the retainer (cressent shape). I can only work on the truck about an hour at a time right now, so the next step is to take off the top end of the engine and remove the lifters--then I can play with the cam and figure out what is up. What I think is up from looking at it is that the retainer is keeping the cam too far into the engine.
Old June 23rd, 2005, 05:06 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
My Crower cam just arrived and there is an expanded flange at the end where the timing gear goes on that keeps the cam from going in too far into the engine. This was either missing or was milled off on the Crane cam and that is what caused all my issues. Few hundred bucks down the drain.
Old June 23rd, 2005, 05:55 PM
stevewhitaker's Avatar
stevewhitaker
Stephen Whitaker
1994 D-90
I hate it when that happens! Good luck on the new cam.
Old June 24th, 2005, 04:27 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Everything is back together with the Crower cam and purring like a kitten! Well, make that a Tiger!
engine
Engine Proble: Please Advise saber6 Defender Technical Discussions 24 November 6th, 2009 10:06 AM
engine noise. Campbell Defender Technical Discussions 31 October 3rd, 2005 10:34 AM
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
whistling noise from engine jstrong98 Defender Technical Discussions 2 December 14th, 2004 11:37 PM
