Noise from bellhousing 300tdi auto - Defender Source
Old August 7th, 2016, 12:19 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
So I'm trying to diagnose the noise from my bellhousing area on the 300tdi auto. I can say with a high degree of certainty it is coming from the bellhousing because when I took off the inspection plate the noise was much louder.
The noise is a banging/clanging metal on metal sound. It's really pronounced at idle but when you're at higher rpms or driving you don't hear it.
First step was to check the torque converter bolt. One of them took a little more but 3 of the 4 were ok. After this snug up the noise went away for about a block but then came back.
So things pointed to the classic broken flexplate issue I've been reading about. Thing is now that the trans is down and flexplate is out....it isn't. The flexplate is ok. One of the TC boltholes is a little stretched out, so maybe part of the issue? I have a new one that I will install anyways. And it had the EDC resistor/sensor ring on there to which I won't be reinstalling.
I did notice that the hollow alignment dowels on the engine side studs aren't installed, never got any on the engine when I bought it. Now that I know they are supposed to be there I will install some. So this could be part of the issue.
I think the shim was a little thin on the crank end, so I will be putting a thicker one I have on there to get me to the 12.4mm as the workshop manual states. My autobox is a 748 with a depth of 18mm that I am currently set at. So the torque converter is still seated correctly.
An observation; if the flexplate is 2.4mm thick and the standoff from the mating surface is 12.4mm then you get 14.8mm. But the TC depth is 18mm. Is 3.2mm too much space? I have a shim that is 2.xmm thick that could soak some of that up. But it seems like I am doing everything by the book and that's what its supposed to be.
So am I missing anything? I'd hate to get it all back together and have this problem persist. I was really hoping to find something broken to know what the issue was. But is all this as simple as no alignment dowels, little thin on the shim (like .10mm, 1.2 to 1.3mm shim), and stretched out TC hole on the flexplate?
Pete
Old August 7th, 2016, 03:04 PM
Broncoduecer
peter
D90
After measuring again just to be sure, I think the original shim is ok. Hard to get .1mm accuracy when you're upside down haha.
Old August 7th, 2016, 04:04 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I'm a little lost on the shim thing,,, where does it go??
When I put my 300 in, I just bolted it to the ZF...I didnt know anything about shims?
Of course, I didnt read the book either...oops! LOL
Rent my
Old August 7th, 2016, 04:19 PM
Broncoduecer
peter
D90
The shim goes on first on the crankshaft end, then the adapter plate, then the flexplate, and then the locking plate.
Something is also not right with the dowels, I ordered FRC5054, they have an OD of 15.8mm but the ID of the holes on the engine/trans are 14.8mm. I don't see them squeezing down that much?
Old August 7th, 2016, 06:25 PM
Broncoduecer
peter
D90
The torque converter bolts also seem to have this wear on the outside, not evenly.
I torqued them through the access panel and not via the starter hole if that makes a difference.
ID:	155252   Click image for larger version
Old August 7th, 2016, 06:37 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Yeah....about those bolts.
Nobody told me NOT to use V8 bolts.
The bolts will hold just the same, but the heads for the tdi are small like D2 TC bolts.
I had to grind down a socket to make a very thin wall socket to fit the V8 bolt heads!
You think that wear is new on youirs?
Rent my
Old August 7th, 2016, 07:39 PM
Broncoduecer
peter
D90
I used brand new bolts for the install so this is recent.
This is what I used, 13mm head: Bolt Secures Flex Plate To Torque Converter (Genuine Part # FS110141M ) - Land Rover bolts\clamps\brackets\washers from Atlantic British
I didn't have any issue getting to them from the inspection plate on the front, where did you go to get access to them?
300tdi, tdi
300tdi to r380 bellhousing fasteners? SkinlessFrank Defender Technical Discussions 5 January 9th, 2016 04:25 PM
300tdi bellhousing sealant??? Wilboro Defender Technical Discussions 5 November 7th, 2015 01:17 PM
R380 + 300Tdi bellhousing Talleyrand For Sale - Parts 4 July 11th, 2015 07:56 PM
Defender 300Tdi Bellhousing for R380 Gearbox Chip For Sale - Parts 3 March 25th, 2015 05:52 PM
WTB: R380 transmission for a 300TDI with bellhousing and shifter Mike Sandone Wanted 1 September 13th, 2011 06:51 PM
