Noise cancelling - Defender Source
Old September 12th, 2010, 09:35 AM
ditskovich's Avatar
ditskovich
dmitry
Range Rover Sport 2013
Noise cancelling
I went over past posts, trying to find the way to lower in cabin noise.
I know it is been discussed on several occasions.
What would you recommend?
Old September 12th, 2010, 12:33 PM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
What did you say???
Earplugs
This is what I did - every trip on the highway over about an hour and I have these on. (I drive a Series / Stage One.)
Firemanshort
1980 Stage One 109
Sterling, VA
Old September 13th, 2010, 12:55 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Seriously. Earplugs. I have earplugs AND Dynamat. For long trips I use noise canceling earbuds that I can listen to music, etc.
Originally Posted by Firemanshort
Earplugs
Old September 13th, 2010, 01:17 AM
orionpco
larry burns
1962 series 2a
from my experience ( jeeps and aircraft cabins) once you have done the simple first things first sound proofing, its time to expand to the fenders and cargo area. even using a sound deadening material under the fender tops and tub sides helps alot. it all adds up. of course with sound deadening material used in mass like this there is no need to use the most expensive and consider the weight properties of the type and brand you are using. two areas i have found that make sounds echo are corners and what i best describe as half tube areas (areas that are bent or shaped like tunnel) . corners seem to amplify sound by allowing the original sound to bounce off as well as creating an echo.
a good rule of thumb is that low frequencies use long flexible panels to travel and high frequencies use corners to bounce back and forth. and for us budget reminded people (my mind says yeah but my wallet says hell nah) any material thats goey or soft works well, just dont pick a meterial that holds or gathers moisture.
Noise from engine--curse of my existence Davis Defender Technical Discussions 25 June 24th, 2005 04:27 PM
lifted d 90 noise 4x4x46 Defender Technical Discussions 11 June 15th, 2005 07:29 PM
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
LT230 noise? Chaucer Misc. Chit-Chat 5 March 19th, 2005 02:59 PM
whistling noise from engine jstrong98 Defender Technical Discussions 2 December 14th, 2004 11:37 PM
