Noise and Vibration out of back end - Defender Source
Old July 14th, 2009, 11:01 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I have this this vibrations and gentle grinding noise that comes out of the rear end mainly when I make right hand turns and I weight the driver rear wheel. I'm 80% sure it's the wheel bearing that needs to be replaced but I thought I would post here and see if there is anything else I shoiuld be checking.
Old July 14th, 2009, 08:55 PM
If its a bearing making the noise I'd expect it to be hot to the touch. Be careful not to burn yourself, but after a decent length drive compare the temperature of all the hubs (you can get cheap IR thermometers these days as well)
Old July 14th, 2009, 09:36 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Stop driving it and tear it down before you add to your parts list for repair, it's not hard to wreck the stub axle. BTW when it comes to bearings there is NO SUCH THING as "gentle" grinding.
Old July 14th, 2009, 10:25 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
What he said.....
Keith
Big, Red and ... aaa Red..
Old July 15th, 2009, 09:10 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I gave the wheel are hard shake and there is a little bit of play. It started happening all of a sudden which makes me question the bearing diagnosis. WHen one of my front bearings blew on the highway the truck hooked across 3 lanes of traffic, not the case here. I guess I just need to open it up and stop posting..
Old July 15th, 2009, 10:04 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
There is a long time between a bearing needing service and coming apart going down the highway. Sounds like you need to step up your preventative maintainance schedule. A new RTC3511 hub seal and a repack and adjust is an annual job on a wheeled truck IMO.
Old July 15th, 2009, 10:06 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I agree with you, truck has 64K miles on it and I've never repacked the rear bearings or changed the seals. I know, I know..
ac
QuietCar noise and vibration reducer cdb Defender Technical Discussions 18 July 6th, 2008 09:42 AM
Banging Noise kiefffff Defender Technical Discussions 22 March 21st, 2007 12:56 PM
noise jimmy salmon Defender Technical Discussions 15 September 25th, 2006 10:26 PM
Drive Line Vibration reggie Defender Technical Discussions 4 May 13th, 2004 12:27 AM
vibration jperakis Defender Technical Discussions 10 October 9th, 2003 02:17 PM
