No Washer Fluid Squirting Out - Defender Source
Old April 13th, 2010, 11:37 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I can force compressed air through the lines and hear the washer pump whirrling. Anyone have any ideas? New pump/washer bottle? Anyone have a dual pump washer bottle laying aorund?
Semper Fi!
Old April 13th, 2010, 11:44 AM
Pull the little one way valve off thats right after the pump and reconnect without it. In my case it was blocking the flow. At the very least you can confirm the whirring of the pump is actually pumping liquid as well.
Old April 14th, 2010, 04:15 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
I think the pumps are available separately
Mike Hammond
Old April 14th, 2010, 12:36 PM
try poking the washer jets out with a pin. they get clogged sometimes (often)
Old April 14th, 2010, 04:11 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I have a large hole in the washer hose that goes to the rear door window. The hole is by the driver windshield pillar (someone screwed a screw through the hose at some point). Can I trim and patch this with a plastic fitting of some sort or do I need to run a complete new hose (=pain)?
Old April 14th, 2010, 04:19 PM
Sure. A regular barb fitting should work fine, but if you are worried about restricting the flow, sleeve it with a piece of tubing that has an inner diameter of the outside diameter of the existing line.
Old April 14th, 2010, 04:34 PM
mikeslandrover
Mike Hammond
I've put a small fuel filter in line just after the pump to stop the jets blocking which used to happen with stunning regularity.
Mike Hammond
Old April 14th, 2010, 08:23 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Tubing sleeve is a great idea. There's very little room once the plastic cover goes over it (left of the windshield, between windshield and side window) so that should do the trick. Thanks!
Station Wagon Rear Washer Squirter mhansen Defender Technical Discussions 2 March 14th, 2009 10:33 AM
Gear fluid ..... Rover- Girl Defender Technical Discussions 3 October 9th, 2005 05:25 PM
Power Steering Fluid Reservior fleabus Defender Technical Discussions 3 July 22nd, 2005 10:39 AM
ZF fluid level goes up and down 48vphantom Defender Technical Discussions 4 March 20th, 2005 01:42 PM
