No Start - yet another - Page 2 - Defender Source
Old January 22nd, 2010, 01:16 AM
back from india .... Saw the Solar eclispe (85% + from where i was) and met a Hindi movie star...
anyway - the truck was at Biggs (my LR shop), started perfectly for 2 weeks daily.
Diagnosis - flooded
odd that it happened to me again on Wensday - start the truck it stumbles then won't start - seems the fuel pump is slightly hyperactive and flooding the engine.
happens randomly - w/o any throttle.
Cure: pull the fuel pump fuse - start the engine (crank a bit) then reinstall the fuse while the engine is running. this uses up the excess fuel and will start the engine (at least once so far for me). can be done from drivers seat in 30 seconds.
i'll update if it happens again and if the "cure" works again - it should
btw.. this was suggested by my mechanic in this situation.
95' D90 - daily driver..
Old January 22nd, 2010, 02:38 AM
Abeer's Avatar
Abeer
Amarveer
94 D90 ST
By fuse do you mean relay? And if so, does this mean you think your fuel pump is completely fine and that the faulty (but cheap) relay is the culprit or do you think its a sign that maybe the fuel pump is on its way out?
Just asking cause im having a similar issue with random no start and stumbling.
start
Truck will not START ? Weldon Defender Technical Discussions 28 December 15th, 2005 12:58 PM
HELP 94 d90 will not start ripp2002 Defender Technical Discussions 64 August 25th, 2005 08:43 AM
Non D90 Technical Question jump start polarity problem dnewman9 Defender Technical Discussions 4 September 6th, 2004 05:39 AM
