No start only click 2.5na - Page 2 - Defender Source
Old October 20th, 2015, 10:56 PM
redline_r
Ridwan
1986/Land Rover 110
Cleaned contacts, still no luck.
On the 86 onwards diagram I see a starter relay, but just cannot find this physical object!
Old October 20th, 2015, 11:52 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Well, obviously time to pull that lump of shit out of your engine bay and put in a 200Tdi. Or an om617. Or an Ls1. Or some hamsters on a wheel, anything would make your truck much more drivable than that 2.5 N/A/POS.
Old October 21st, 2015, 01:32 AM
Ignotus
gene
1960 109, w/200TDI
Have you tried, making a jumper for the wire soleniod spade terminal and having just a bare wire on the other end then touching the + wire at the starter with it? Even with the key off the starter should turn so be careful and have it out of gear. Doing this bypasses the ignition and can give a clue to wether the soleniod or the small ign wire are bad.
Have you checked with a test lamp you are getting power to the ign/starter wires when key is in ign position?
Is the + wire on the starter tight?
Gene
1960 109
1960 88 Ignotus
Blog;
Old October 21st, 2015, 02:13 AM
I too had this same issue after The paint was baking soda blamed from my ExMOD 90. I hit the starter, solenoid, the relays behind the fuse panel and the ignition switch with compressed air. It cured the problem.
start
Start no start leastonce Defender Technical Discussions 10 February 25th, 2012 02:33 PM
WTS: 2.5na diesel engine (in CANADA) headdamage For Sale - Parts 2 April 1st, 2008 04:36 PM
Turn the key and . . . CLICK! Bozman Defender Technical Discussions 15 January 25th, 2007 02:57 PM
Won't start...only when it rains gravitysucks Defender Technical Discussions 8 January 4th, 2006 12:07 PM
Click...Click...Click... bjenk Defender Technical Discussions 10 February 15th, 2005 09:05 PM
