No start in Breckenridge ... - Page 2 - Defender Source
Join the Defender Source Community Today
Old September 9th, 2016, 08:31 PM
If you ever think you have a flooding issue (often caused by the coolant temp sensor or wiring) you can unplug the inertia switch and then try cranking with the pedal to the floor. The engine will usually sputter or start on the fuel in the cylinders if that is the case.
Old September 10th, 2016, 04:30 PM
Moab ... All good!
Old September 10th, 2016, 04:59 PM
Do you have access to a live chicken?
He must have !
95' D90 - daily driver..
Old September 11th, 2016, 06:11 AM
sad_story's Avatar
sad_story
andre
95' D90
For what it's worth ...
Had a similar issue last weekend, driving around normally and as I pull into the driveway, truck stalls and refuses to start up again...
I reached you to a couple of go-to. All gave great advice which I ignored as i thought "too simple".
About a month ago, car did something similar, I ended up at a dealership and the simply replaced the rotor & cap.
When I was advised to check that last week, I said to myself "no way, they are both new"
Lesson learned - a week of fiddling about in short spurts. I put in the rotor that I had recently replaced and the truck started immediately....
In short listen to the guys that know better ...
start
Breckenridge Distillery Jbirdlott Misc. Chit-Chat 9 May 24th, 2016 10:51 AM
Start no start leastonce Defender Technical Discussions 10 February 25th, 2012 02:33 PM
D-90 stuck in Park, Won't start. HELP!!! brianosaurus Defender Technical Discussions 9 December 12th, 2007 09:45 AM
Ignition Relocation = No Start...Help JRowe Defender Technical Discussions 5 March 8th, 2004 12:45 PM
