No start fuel pump? - Defender Source
Old September 20th, 2015, 12:56 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
So the 90 has been laid up for a bit with clutch issues. Been starting it in the garage on a regular basis. Today while working on the clutch, it will not start. Cannot hear the fuel pump coming on but when I turn key off can hear it for a couple of seconds. Any ideas? Thanks
"I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." - Arthur
Old September 21st, 2015, 09:50 AM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
I'm no expert:
Check the inertia switch. It's a safety shut off switch either near the fuse panel area under the dash. Others found it on the engine side of the fire wall.
Double check the relays under your dash. Maybe 2 metal ones (with brown line).
Old September 21st, 2015, 10:53 AM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Yes, checked the inertia switch, not that. Is there a way to check the relays or just buy new? If so are they readily available at auto parts store or Rover specific?
Thanks!
Old September 21st, 2015, 12:49 PM
Thanks!
if you put your finger on you might be able to feel them click ... swap them in case one is faulty.
The noise you hear when turning off is not the fuel pump but the AICV resetting ready to start next time.
Oh and if you've been playing near the coil ... knocking the white wire with a black trace off the coil will cause a no start as its the ignition pulse signal to the ECU. No pulse ... no fuel pump!
Old September 21st, 2015, 06:25 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Hmmmm. I'll check those. Thanks!
Old September 21st, 2015, 07:57 PM
Long day for sure, but this threw me for a minute until i messed around with the comma
if you put your finger on you, might be able to feel them click ...
if you put your finger on, you might be able to feel them click ...
Old September 21st, 2015, 09:46 PM
ezzzzzzz
Mark Garrenton
For starters check actual pressure. If you don't have a fuel pressure gauge (why not???) just turn the key to run then back off, then push in the schrader valve on the fuel rail to see if you have any fuel pressure (it will spray a bit if it's there). This non-gauge test will at least tell you if the pump is functioning at all. If ont, the next step is checking for voltage going to the pump preferably at the tank wiring. It goes backwards from there. Analytical troubleshooting is your friend.
Old September 21st, 2015, 10:22 PM
Originally Posted by LostChord View Post
Long day for sure, but this threw me for a minute until i messed around with the comma if you put your finger on you, might be able to feel them click ... if you put your finger on, you might be able to feel them click ...
Next time I'll bust out a semicolon ... I apologize for my tardy punctuation.
Did you test it?
Replaced fuel pump, truck won't start chris snell Defender Technical Discussions 1 July 23rd, 2010 12:29 PM
fuel pump fuse keeps burning, no start ditskovich Defender Technical Discussions 12 February 4th, 2010 07:05 AM
YANST (Yet Another No Start Thread) - fuel pump circuit issues cgalpin Defender Technical Discussions 25 August 2nd, 2009 11:23 PM
1994 D-90 Will Not Start-fuel Pump? QUEST Defender Technical Discussions 17 March 10th, 2005 06:54 PM
