no start... ECU? - Defender Source
Old August 3rd, 2010, 12:40 PM
MikeRuby
Mike Ruby
'95 D90 #2523
no start... ECU?
95 3.9L
starter cranks, but engine won't fire...
fuel pump 7.5A and fuel injector 30A fuse under the hood are both fine...
replaced the two relays in passenger seatbox with local auto parts store's 30A relays (not too many parts store options on the island); no change...
Tried Ron's previous post advice about pushing the accelerator all the way to the floor for a ten second crank to ensure she's not flooded... no luck.
Starter fluid squirt allows the engine to run fine...
Seems as though the fuel injectors are not getting electrical input... So it's the ECU?
What am I missing?
cell: 508-221-7144
Old August 3rd, 2010, 01:12 PM
owen's Avatar
owen
Owen Jones
Yellow`95 D90 ST #2188
Can you hear the fuel pump whirring when the ignition is turned on? If not try resetting the famous Inertia cutout under the bonnet on the top RHS of the bulhead.
"I think you need a little weatherstripping - right here..."
Old August 3rd, 2010, 01:25 PM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
Is this the first time happening?? check wires, plugs, coil, etc.... fuel filter?
Old August 3rd, 2010, 01:30 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Are your brake lights working? All rear electrics?
Reason I ask is I had a problem with a short in the rear harness that was limiting the voltage to the fuel pump and making the truck not start or if it started it would run long.
Good luck
Old August 3rd, 2010, 01:44 PM
I'd second this ...
Old August 3rd, 2010, 01:52 PM
MikeRuby
Mike Ruby
'95 D90 #2523
Famous? WTF... I'm not a total dumb-arse, but cannot locate it... okay maybe I am a total...
Is it at the very top of the bulkhead... black 1.5" square, with a rubber cap on top covering a white 3/4" round plasitc?
If yes, it was not tripped... If that's not it, where is it exactly on a 95?
Many thanks guys...
Old August 3rd, 2010, 03:34 PM
You don't say if you can hear the fuel pump or not. Also I'd get the real deal for the relays before doing anything else since the ones you got at the parts store may actually not be the right ones. You can get them overnighted from one of the vendors (AB has affordable black ones).
Old August 3rd, 2010, 03:51 PM
For the silver relays I had found these a month or so ago.
http://www.defendersource.com/forum/...ad.php?t=26333
Old August 3rd, 2010, 04:34 PM
MikeRuby
Mike Ruby
'95 D90 #2523
cannot hear the fuel pump... real Bosch relays just arrived, had 'em overnighted... still not sure I've located the inertia cutout, might it be somewhere else?
Old August 3rd, 2010, 04:43 PM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
inertia by fuses under bonnet, behind plenum attached above firewall, under windshield..... i have a 95 as well.
I had similar (as many of us do) no start...... check main grounds, clean ALL connections, check wires and relays as people mentioned..... I never quite figured out what was causing my no starts but changed a bunch of needed stuff and voila..... it starts..... for now......
Old August 3rd, 2010, 05:22 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
clean all the connections on the ignition coil, sometimes the one for the RPM feed to the ECU gets corroded.
My oil line fix
My 100k stopped odometer fix
Old August 3rd, 2010, 05:29 PM
LRover's Avatar
LRover
J. Michael McCaig
If it runs on either, it's not an ignition problem. It must not be getting fuel. Make sure the fuel pump is getting 12v, check fuel pressure.
Old August 3rd, 2010, 05:36 PM
Can't hear the fuel pump after putting in proper relays? Maybe time to check if you are getting voltage to the pump, that it's grounded etc. They do go bad so if you are getting voltage to it on the firt turn of the key it might be bad.
Inertia switch is behind center fuse block in a '94 - don't know about a '95.
Good luck,
charles
Old August 3rd, 2010, 05:47 PM
Dead fuel pump for sure.
Old August 3rd, 2010, 05:56 PM
Could it possibly be the ignition switch (inside the dash, Mike...behind the speedo)? I was getting key position 3 (starter) like you, even with a faulty switch, until it completely broke the next day or two later - I too had initially thought ECU or fuel pump (wrongly). They don't seem to all fail the same way, so you may have key positions 1 and 3 work, but 2 (the position that initiates the fuel pump) may not be functioning. It's a $17 or so part, $25 with shipping overnight. Mine works fine now after replacement.
Old August 3rd, 2010, 05:58 PM
MikeRuby
Mike Ruby
'95 D90 #2523
Thanks guys for all your assistance... Charles was right, the real Bosch relays worked... shitty local replacement ones were crap... FYI, I found them at autopartswherhouse.com for about $16 each...
Once again, thanks for all your diagnostic assistance...
Old August 3rd, 2010, 06:13 PM
Whoohoo! A shitty day made worthwhile.
Was this the one that had been sitting for a while Mike? I think you had posted before about it.
Old August 3rd, 2010, 06:30 PM
MikeRuby
Mike Ruby
'95 D90 #2523
Yep, she had been sitting for about two and a half years when I bought her (outside under a bimini top and a $10 blue tarp, no less)... but I have a really great mechanic friend out here that helped me give her a lot of love (and $3500 worth of parts) back in Nov'08 when I started... She's been my daily driver, and since it's such a small island I take the 'long' way to the office, but I know I'm not driving her enough... Other than that, she's in great shape for as hard as this island is on steel.
Is it safe for me to presume the long sit had an effect on the relays?
Old August 3rd, 2010, 06:36 PM
Yeah I think they just fail over time but I am sure sitting doesn't help.
ecu, start
Speed Sensor and ECU Issues DJ Menasco Defender Technical Discussions 14 February 16th, 2006 08:45 PM
Bad Flasher tic-tock?! OCD90 Defender Technical Discussions 4 December 13th, 2005 02:13 AM
HELP 94 d90 will not start ripp2002 Defender Technical Discussions 64 August 25th, 2005 08:43 AM
