No Start After Tune-up - Defender Source
Old August 21st, 2009, 06:42 PM
District 90's Avatar
District 90
BENJAMIN/LEE
1994/DEFENDER 90
Cool No Start After Tune-up
Performed a tune-up using NGK plugs, Bosch premium wire set, and a new distributor/rotor cap yesterday. I can hear the starter, but the ignition is not turning over (sounds and feels healthy, though).
None of the wires are touching and relatively crossing at 90 degrees. I thought it was a mis-wire (the Bosch set is un-numbered and I matched them according to length compared to the previous wire set). Is there a chart referencing the serial numbers on the wires to the appropriate numbers? The only wires that are close in length are the #3 and #5 wires; and I've tried both combinations, yet still no start.
Any suggestions?
E.T.
Old August 21st, 2009, 06:45 PM
Have you checked the distributor, make sure it is in correctly? Maybe try putting the old one back in. Also, from what I under stand Rovers run best on the cheap Champion plugs.
Old August 21st, 2009, 07:23 PM
District 90
BENJAMIN/LEE
1994/DEFENDER 90
Cool Re: No Start After Tune-up
The distributor and rotor are proper. The old one broke while removing the #1,3, & 5 wires. This D90 is solid and ran on NGK's. The original starter lasted for 13 years. Perhaps, the Bosch wires work better with Champion plugs? Been troubleshooting and that may be an alternative.
Thanks, for your advice, Scott.
Cheers,
Ben
94 D90 #331
Old August 21st, 2009, 07:51 PM
Not the wires or plugs.
Old August 21st, 2009, 08:12 PM
You knocked a wire off the ignition coil or ignition module.
Old November 12th, 2009, 04:28 PM
District 90
BENJAMIN/LEE
1994/DEFENDER 90
It was resolved sometime that week: a misconnected coil wire (ground). A good neighbor helped point it out for me. A very simple fix.
Thanks, everyone, for your responses. Peace.
start
HELP 94 d90 will not start ripp2002 Defender Technical Discussions 64 August 25th, 2005 08:43 AM
Non D90 Technical Question jump start polarity problem dnewman9 Defender Technical Discussions 4 September 6th, 2004 05:39 AM
Ignition Relocation = No Start...Help JRowe Defender Technical Discussions 5 March 8th, 2004 12:45 PM
