No start after tune-up - Defender Source
Old August 21st, 2009, 06:36 PM
District 90's Avatar
District 90
BENJAMIN/LEE
1994/DEFENDER 90
Performed a tune-up using NGK plugs, Bosch premium wire set, and a new distributor/rotor cap yesterday. I can hear the starter, but the ignition is not turning over (sounds and feels healthy, though).
None of the wires are touching and relatively crossing at 90 degrees. I thought it was a mis-wire (the Bosch set is un-numbered and I matched them according to length compared to the previous wire set). Is there a chart referencing the serial numbers on the wires to the appropriate numbers? The only wires that are close in length are the #3 and #5 wires; and I've tried both combinations, yet still no start.
Any suggestions?
E.T.
start
HELP 94 d90 will not start ripp2002 Defender Technical Discussions 64 August 25th, 2005 08:43 AM
Non D90 Technical Question jump start polarity problem dnewman9 Defender Technical Discussions 4 September 6th, 2004 05:39 AM
Ignition Relocation = No Start...Help JRowe Defender Technical Discussions 5 March 8th, 2004 12:45 PM
