no start after extensive rebuild - Page 2 - Defender Source
Old February 27th, 2012, 03:47 PM
Originally Posted by pendy View Post
So I disagree with you Red. It is such a simple thing to double check, so I wonder why you would bother to disagree with me. And it is an important step if components like the injection pump are operating without fluid in them. I know you see the logic in this.
I agree with you fully...
I was more trying to get the OP to be clear on what he really meant.
Old February 27th, 2012, 04:40 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Oh I hate harmony
Best to bleed the fuel system with the mechanical arm on the lift pump or a suction canister from the Injection pump Elvis.
Cranking the engine to bleed the fuel system on a dry Injection pump is just asking for trouble. And after you learn the correct method it take less time to do it right.
Will be great to hear you are burning fuel again soon.
legend in my own mind
Old February 27th, 2012, 09:19 PM
Surfin' Elvis
Chuck
95 RRC 300tdi/wvo conversion
Went to 5 hardware stores...no go on the washers. @#!*#
Gonna go to fastenal dealer tomorrow. Can't find any sources for the washers outside of the uk.
Any ideas?
Old February 27th, 2012, 11:10 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Go to or call your local NAPA, copper crush washers are commonly used on oil pan drain plugs. I get 2 with each oil filter kit for my 524td
Old February 27th, 2012, 11:43 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Did you get any washers with your gasket kit. Seems like some of the small ones are in there.
Old March 9th, 2012, 09:24 PM
Surfin' Elvis
Chuck
AB had the washers...well, they had 6 and 2 are on "back-order". Replaced copper seal washers on cylinders #1-#3, #4 not leaking at present.
Still no start condition. Here is what I know:
Timing pin inserted neatly into pump flange while woodruff key on crank was at 12 o'clock and cam gear mark lined up with casting mark as in the manual. Flywheel locking pin was inserted as well.
Fuel is pumping out of tops of loosened injector fitting when cranking.
Compression test completed. Cylinders #1-#3 @ 340-360psi. Cylinder #4 @ 325 psi.
Unobstructed air flow to the intake side of the turbo.
Engine will run for a second or less when I atomize a small amount of gasoline directly into the intake chamber, but produces a lot of white smoke from somewhere. By the time I am able to get a look under the hood after depressing my pushbutton starter, the white smoke's origin is unable to be identified.
Any guidance will be appreciated.
Old March 9th, 2012, 11:17 PM
Tino.R's Avatar
Tino.R
Tino Rebelo
67/series IIA
Do this simple test and find out if you did the same mistake as me that took me two weeks to find.Unplug wire from fuel solenoid and plug test lite to it,hang the lite so u can see'it from inside the truck.Crank the starter (in your case the starter button) and see if you have power while you cranking.if no power you found it.
Old March 10th, 2012, 06:40 AM
Surfin' Elvis
Chuck
Yep, checked it. Thanks.
Old March 10th, 2012, 12:33 PM
Surfin' Elvis
Chuck
Slight adjustments produced the following compression results:
#1 - 390 psi
#2 - 380
#3 - 380
#4 - 340
Old March 10th, 2012, 01:00 PM
Surfin' Elvis
Chuck
#1 - 390 psi
#2 - 380
#3 - 380
#4 - 340
Old March 10th, 2012, 09:19 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Just thinking, Your flywheel should have two indentations in it. Don't know why? but, both of mine did/do. Could you check to make sure you are at TDC when everything is lined up? Seems like you have checked everything else.
Land Rover 110
rebuild, start
Truck will not START ? Weldon Defender Technical Discussions 28 December 15th, 2005 12:58 PM
Ideas for CVC's "banana flambe" rebuild evilfij Misc. Chit-Chat 24 September 23rd, 2005 01:10 PM
HELP 94 d90 will not start ripp2002 Defender Technical Discussions 64 August 25th, 2005 08:43 AM
