No start - Page 2 - Defender Source
Old September 8th, 2006, 10:05 AM
Sometime Sunday would work for me, maybe Saturday afternoon. No magic dust, but sometimes a second set of eyes/ears helps.
I usually just get Hippart on the phone when I get really stuck
charles
Old September 8th, 2006, 12:02 PM
Charles I tell him to call me, but he messanges me at about 11pm at night, and I'm not exactly in my "rover" trouble shooting mode at that time.
Old September 8th, 2006, 10:42 PM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
Finally! I get to hear the sound of the V8 again.
Thanks to Trevor, Mike and all the rest of you for the ideas. I think it was a case of bad flooding, and my own bad troubleshooting which made it worse.
Here's a couple of lessons learned for the archives:
1. When you floor the throttle, it tells the computer that you're clearing a flooded engine and won't send any fuel to the injectors. I think that I must have been starting with the throttle only partially open and it kept dumping more fuel into the cylinders
2. You need to have the air intake, the MAF connector, and all the other connectors when starting. I had pulled a couple of things when troubleshooting and I'm sure I just confused the computer even more.
I guess I should have payed more attention in Auto Shop class in high school
Steve mentioned that he flooded the truck so badly that gas got into the oil. I'm smelling gas in my oil too, I think.
How bad is that?
thanks again all!
Old September 8th, 2006, 10:56 PM
Just change the oil and you should be fine. Gas in the oil is one of the main reasons you change the oil every 3000 miles or so. It breaks the oil down. Glad she's running!
Old September 9th, 2006, 08:54 AM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
How bad is that?
thanks again all!
Change the oil before you run the engine. I spun the main bearings in a carb. engine once from the same problems that you are having.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
Old September 9th, 2006, 10:59 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
That is awesome! Congrats on figuring it out!
start
Truck will not START ? Weldon Defender Technical Discussions 28 December 15th, 2005 12:58 PM
HELP 94 d90 will not start ripp2002 Defender Technical Discussions 64 August 25th, 2005 08:43 AM
Ignition Relocation = No Start...Help JRowe Defender Technical Discussions 5 March 8th, 2004 12:45 PM
