No Start - Defender Source
Old May 21st, 2014, 11:16 PM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
No Start
Was sitting idling tonight waiting for my daughter and my 94 D90 just died.
No stumble or sputter...just shut off.
Tried turning over a bunch and it finally turned over and ran for 10 second.
Opened the gas cap.
Added fuel
Replaced Silver relays
Generally stared under the hood in confusion
Still does not start.
Over the past month is has been exhibiting the following symptoms:
"smells" like it is running rich
dying at idle (but would restart)
Any troubleshooting tips?
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old May 21st, 2014, 11:56 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
usual suspects check plugs cap rotor wires,possible bad ignition module (breaking down from heat )
No Mall crawler here
Old May 22nd, 2014, 12:05 AM
x2 on the ignition amplifier module...
Old May 26th, 2014, 08:24 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
Just went and spent a few minutes looking into this:
No spark at the lead from the coil to the distributor cap.
Still the ignition amplifier? Anyone have a link the the replacement procedure?
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old May 27th, 2014, 12:42 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
Now it gets interesting....
Didn't have time to fix so I called a tow.
Decided to try an fire it up instead of pushing it out of the garage....and it runs GREAT.
Tried starting it 10-15 times over the weekend...and now it randomly started.
Ran it for 45 min in the driveway to see if it failed on heating up...running like a champ.
Any ideas? Totally confused now...because if I bring it in...they will have a hard time diagnosing...
I did remove the connectors from the Ignition Amp and wiggled some stuff...
Dave
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old May 27th, 2014, 06:28 PM
I try to expand later when I'm not typing from the phone, but mine was a very similar experience with my ignition amplifier module. It got so bad to the point like you describe above where it would barely start or run at times...but at other times it would. I was in a time crunch, and bummed a used module from Galpin and threw it in at Huffs since he had a timing light (you can do it carefully without messing with the timing, but we were leaving on a wheeling trip and I didn't want to risk screwing it up).
Anyhow that instantly solved the problems. However, it's been probably been a year or so and every once in a blue moon I have a similar issue - today being one of those where it started to be down on power, over fuel, and start knocking. In cases like this a simple shut off / turn on does not work...I actually have to use my kill switch (which disconnects the battery) and then it fires right up. I presume that the kill switch resets the ECU or something.
Anyhow, I have the ignition amp relo kit from AB and plan to put that in ASAP. If it were me in your situation, I'd probably spring the $150 for the kit (which includes a new module...by itself that runs $75-80). It's worth a shot, and bottom line is they make these kits for a reason - it's a known issue, so even if it ends up not being your issue I think it's a worthy upgrade anyhow.
One thing you may want to try in the interim is disconnect your battery to see if it resets the ECU and will allow you to start. But if the module is shot it may not matter.
Old May 19th, 2016, 11:24 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
Just an update on this. It WAS the ignition amp and put in the relocation kit...not issues for the last year!
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
start
Start no start leastonce Defender Technical Discussions 10 February 25th, 2012 02:33 PM
D-90 stuck in Park, Won't start. HELP!!! brianosaurus Defender Technical Discussions 9 December 12th, 2007 09:45 AM
Dies after start benh Defender Technical Discussions 2 May 20th, 2004 03:04 AM
Ignition Relocation = No Start...Help JRowe Defender Technical Discussions 5 March 8th, 2004 12:45 PM
