No Spark ignition amplifier? - Defender Source
Old August 5th, 2016, 01:00 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Does anyone know how to test the ignition amplifier or distributor? The defender stalled at a light, I didn't even noticed it shut down, and I haven't been able to restart it since.
It is not getting a spark to the plugs. Spark is coming from the coil but it ends there. Cap/rotor (genuine) and plugs/wires were all replaced in the last 12 months.
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old August 6th, 2016, 12:01 AM
Broodster's Avatar
Broodster
K L
1989 90 V8 County
This happened to me - after pulling everything apart, I finally noticed that the spring loaded node from the cap that connects to the rotor was gone....
Worth a quick look.
Old August 6th, 2016, 02:41 AM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
Originally Posted by lordhelemt View Post
Cap/rotor (genuine)
If you are referring to the recently minted (& re-branded) "Lucas" rotors, then that could possibly be your problem. Some techs consider them complete junk, & if they are correct, then having nigh to 12 months on one can be even more of an issue.
Otherwise, it's really way above my pay grade, but I believe I recall reading somewhere that distributor testing is...ugh, I'm really feeling queasy about posting this...perfomed by spark testing the negative terminal of the coil? And by pulling off the cap & observing as to whether the rotor is turning when you hit the starter?
Oh well, if I'm completely wrong, hopefully someone knowledgeable will jump in & correct me...
Old August 6th, 2016, 03:48 AM
I swear having extra rotor and cap on hand is smart. My own no start scenario was frustrating as all heck.
Then one day I put on a new cap and bingo, purring like a Rover V8 should.
Old August 6th, 2016, 08:18 AM
lordhelemt's Avatar
lordhelemt
Paul
Thanks all for the suggestions.
I've replaced the cap/rotor and coil with known good units and zilch. Also checked to make sure the rotor is turning while cranking the engine and it appears to be fine.
Will replace the wire and see if that makes a difference. Will report back but this does have me baffled.
Old August 6th, 2016, 08:27 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Ignition testing pages from '95 RRC WSM but should be the same for you.
https://www.dropbox.com/s/zi4ap3gldo...sting.pdf?dl=0
Old August 6th, 2016, 09:33 AM
lordhelemt's Avatar
lordhelemt
Paul
Thank you!
Old August 7th, 2016, 07:26 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
If you got spark making it to the cap then you only have to test the cap, rotor, pick-up, and amplifier.
Ignition Amplifier Relocation Kit Rugbier Wanted 13 June 17th, 2011 05:55 PM
Ignition Amplifier Module Relocation Kit (STC1856) jimngo For Sale - Parts 27 November 23rd, 2010 07:52 PM
New STC1212G Amplifier Module Link Lead and Stock Ignition Coil nimbusnic For Sale - Parts 0 December 29th, 2008 04:54 PM
Good Spark, Bad Spark Big D Defender Technical Discussions 4 August 19th, 2008 09:43 AM
Wanted: ignition amplifier module for 3.9L V8 cgalpin Wanted 3 November 2nd, 2007 05:17 PM
