No Spark - Defender Source
Old August 18th, 2005, 12:44 PM
Billakris's Avatar
Billakris
Kris
Alpine White 95 Soft Top
Exclamation No Spark
Hey guys,
I washed the 90 last night, and may have gotten some water in the engine bay so now she wont start. I know this has been discussed before, but I couldnt seem to find what you guys used as the solution.
Just so you know, the fuel pump turns on, and the starter cranks, but there is not spark at the plugs so she wont turn over. I let it sit over night, but still no go
Please help with this one,
FOLLOW UP
so it has been out in the sun all morning with the hood up. I really dont think i soaked anything this much....
Does anyone know what this could be?
I didnt think it was associated, but last week the car wouldnt start on 2 separate occasions. One was after i had been at work all day, and the second was after i stoped to get gas. Both times the car was running perfectly before i turned it off. This is really confusing me.... Any Ideas are appreciated
Thanks again
Kris
Old August 18th, 2005, 03:32 PM
Billakris's Avatar
Billakris
Kris
anyone?
Kris
Old August 18th, 2005, 03:44 PM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
It might be worth your while to pop open your distributor and make sure it's dry in there. Those little connections at the coil are always good for a wiggle or two.
Old August 18th, 2005, 03:58 PM
Any spark from the coil? Are all the conections good on the coil and distributer?
Old August 18th, 2005, 04:19 PM
Billakris's Avatar
Billakris
Kris
Mike,
How do i check for spark at the coil?
Kris
Old August 18th, 2005, 04:27 PM
Pull the middle wire off the distributer you should get a spark between the wire and something grounded, you may have to stick a screwdriver or something metal in the wire if the spark isn't strong enough to jump out to ground.
Oh and I have the test sheet for the dist in this thread.
http://www.defendersource.com/forum/...ead.php?t=5559
Old August 19th, 2005, 12:01 AM
Billakris's Avatar
Billakris
Kris
Rod and Mike, thanks for the help and link. I ran through the checks and found out i should get some new wires for the plugs, and that there was no spark at teh coil. So i ordered a new coil and wires from the auto store (is it the E520?)
Well see how it goes tommorrow
Kris
Spark plug recommendations tron Defender Technical Discussions 18 March 31st, 2006 07:00 PM
While changing spark plugs mdmccallum Defender Technical Discussions 9 November 2nd, 2005 09:12 AM
No Spark evilfij Misc. Chit-Chat 2 September 4th, 2005 07:22 PM
no spark suggestions? mattdh Defender Technical Discussions 12 April 25th, 2005 09:59 PM
SPARK PLUG Change Interval: norros Defender Technical Discussions 2 February 21st, 2005 03:03 PM
