No spark? - Defender Source
Old May 25th, 2012, 01:45 PM
usadventureracing's Avatar
usadventureracing
Brett
110
No spark?
I now have no spark. I have power to distributor, but no power to the plugs. I have all new wires and plugs. Any advice would be helpful.
1983 ROW D110
1970 Series III (Parting out)
Old May 25th, 2012, 01:59 PM
usadventureracing
Brett
110
I have the v8 305 if it is the distributor is there a none Lexus I can get at a local auto store?
1983 ROW D110
Old May 25th, 2012, 02:00 PM
Naplm00
Matthew
How does that cap and rotor look? Did you replace these last week? Also is the dizzy fully inserted and operating when the engine is cranking?
Possibly check spark with an old plug and the main lead coming from the coil to the dizzy cap. Connect it somehow to the plug, place plug on grounded area and crank the engine to see if you have spark coming from the coil to the dizzy
Old May 25th, 2012, 02:01 PM
usadventureracing
Brett
110
Lucas
------ Follow up post added May 25th, 2012 01:03 PM ------
There is power to the coil on both sides could that still not produce spark? As for the cap and rotor looks good I got the new rotor but have not installed it
1983 ROW D110
Old May 25th, 2012, 02:35 PM
Naplm00
Matthew
Originally Posted by usadventureracing View Post
Lucas
in the case of a bad coil, yes
Old May 25th, 2012, 02:54 PM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
Agree on the cap & rotor.
Old May 25th, 2012, 03:09 PM
usadventureracing
Brett
110
Installed me coil and rotor cap is good. What about module on dizzy?
1983 ROW D110
Old May 25th, 2012, 04:03 PM
usadventureracing
Brett
110
Anyone have a part number for a distributor other than a Lucas for a v8 305 that I can get at stores like autozone or napa
1983 ROW D110
Old May 31st, 2012, 07:03 PM
usadventureracing
Brett
110
Ok got a new dizzy installed but now I cannot get the timing correct as I cannot move the dizzy far enough as the alternator bracket is in the way. Any suggestions? Could I have installed the dizzy wrong? Thanks in advance
1983 ROW D110
Old May 31st, 2012, 07:16 PM
usadventureracing
Brett
110
She runs now but just cannot get her timed.
1983 ROW D110
Old June 1st, 2012, 07:41 AM
usadventureracing
Brett
110
Fixed the issue last night. Moved the plugs one position over in the same firing ordering. Now she runs like a champ in the garage, now need to test drive today.
1983 ROW D110
Spark plug recommendations tron Defender Technical Discussions 18 March 31st, 2006 07:00 PM
No Spark evilfij Misc. Chit-Chat 2 September 4th, 2005 07:22 PM
No Spark Billakris Defender Technical Discussions 6 August 19th, 2005 12:01 AM
no spark suggestions? mattdh Defender Technical Discussions 12 April 25th, 2005 09:59 PM
SPARK PLUG Change Interval: norros Defender Technical Discussions 2 February 21st, 2005 03:03 PM
