No smoke no poke lol - Defender Source
Old April 25th, 2015, 02:22 AM
DIZZY
darren
1987 land rover 90
Hi
I have recently bought a DEFENDER with a Disco 200tdi conversion, very powerfull compared to any other defender or 200 I have drove but bellowed black soot out all the time when accelerating and if I laboured it, the smoke was that bad I couldn't see cars behind turns out it had one of those boost pins fitted, so I have removed it and replaced it with a standard pin now its a totally different vehicle it doesn't smoke even under load there is nothing I had a friend follow me and said if there was it was minimal and he could hardly see it but It does feel really slow now as if the turbo seems a little lazy? it has a boost guage fitted and with the boost pin it would hit 15psi in seconds now it struggles to hit 15psi more like 0.8psi but in 5th or 4th when speeds up it will go to 13psi is this underfueling should I be concerned?
Old April 25th, 2015, 08:11 AM
87 D110 (Ruby)
You are now in a typical 200tdi...boost pins Rock. Try it again with boost pin and retard the star wheel a few clicks
There is also a nylon washer that you can which will help, but you need to file it down before using it
Old April 25th, 2015, 08:38 AM
The stock pin has different profiles depending on how you installed it. Which setting did you use?
FS White Bling RR on CL not mine LOL Broncoduecer The Flea Market 1 October 29th, 2013 09:55 AM
LOL, a 90 I can afford NealK The Flea Market 9 May 28th, 2011 06:13 PM
Wow another rare one...LOL bitz The Flea Market 7 January 20th, 2011 10:37 AM
Wow what a deal...LOL! bitz The Flea Market 0 September 17th, 2009 01:10 PM
