No Rear Lights - Defender Source
Old August 21st, 2016, 09:10 PM
gwmckee
George
1994 NAS D90 #1919
No Rear Lights
Well, my build is going pretty well but ran into a snag today. For background, I have a 1994 NAS 90 soft top that I have been restoring for the better part of the last 10 months. Engine , transmission and transfer case rebuilt and are working fairly well. Swapped in a new galvanized frame from Rovers North. Every nut and bolt on the truck has been cleaned or replaced.
Here is my problem... no lights work on the back of the truck (brake, reverse, indicators, license plate lamp or either side marker). All other lights work fine with the exception of the "fast blink" on the turn signals (this is likely due to the fact that the rear indicators are not working). I've taken out a bunch of ghost wiring during this project and am not sure if I missed a connection somewhere. Is there a master connection to the rear lights somewhere? Seems to me like the rear harness is not getting power.
Thanks in advance for the help.
Old August 21st, 2016, 09:52 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
The rear harness connects near the passenger side foot wheel. You Should see it come out of the the chassis by the outrigger. Follow it up and see if it is connected. Test light and power prob will be your friend....
Old August 21st, 2016, 11:02 PM
gwmckee
George
1994 NAS D90 #1919
Yep. Right after I hit send on my post, I had a beer and then started tracing the rear harness. Turns out there are several connections next to the heater box where the rear harness connects to the main harness. There are two sets of connectors... One white and the other black. I had the black connectors plugged into the white socket and the white connector into the black socket. Once I switched white to white and black to black, viola!
ht, lights
LED fog lamps work lights fog lights Ben01 For Sale - Parts 2 April 20th, 2015 09:42 AM
Running Lights / Interior Lights Short Wolf Fabrication Defender Technical Discussions 21 February 17th, 2012 06:27 AM
How to Convert 1994 rear Square Lights to 95-97 LED lights FlaD90 Defender Technical Discussions 7 November 20th, 2011 04:34 AM
For Sale - Rear Lights, Rear Step Tread and Vent Covers Reese_D90 For Sale - Parts 7 February 5th, 2011 08:02 AM
Left brake lights work....the right and door brake lights won't? beko35 Defender Technical Discussions 4 June 27th, 2009 01:12 PM
