no power to 2.5t starter - Defender Source
Old September 4th, 2016, 08:38 PM
Pinckney73
Pinckney Thompson
Defender 90
Need some help. I have a Defender 90 with a 2.5t. When I turn the switch, the plug in relay is clicking but my starter won't engage. It was doing this every now and then, but now it won't start at all. New battery and replaced the relay just so. Any ideas appreciated.
Old September 4th, 2016, 08:43 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Check grounds off starter. Check all connection on starter. Tap starter solenoid with hammer.
~ Semper Fidelis ~
Old September 4th, 2016, 09:08 PM
dlbriller
Doug
1987 ex-MOD 'Tithonus' Defender 110
Had a similar problem with mine that was caused by a bad ignition switch. It started out as intermittently not starting, just getting clicks from the relay, and eventually devolved into nothing happening when the ignition switch was turned. I bypassed the starter position of the switch (everything else worked fine) and just hooked it up to a push button.
start, starter
Starter Problems Trigger Defender Technical Discussions 10 September 27th, 2006 10:00 AM
Starter going bad? loykd Defender Technical Discussions 6 September 15th, 2004 10:12 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
Can't remember starter wiring Heath Defender Technical Discussions 5 February 15th, 2004 10:59 PM
how much should I pay for a starter Campbell Defender Technical Discussions 5 November 4th, 2003 02:38 PM
