No power...no crank..whats up? - Defender Source
Old April 27th, 2014, 07:56 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
Last time I tried to start I got a hard thud with no turnover. Brand new diehard battery. I do have driving lights but that's it. All fuses look good. After trying to start a good dozen times my key kind of got stuck in the crank position...no spring back. Is this a faulty ignition issue or new starter?
Old April 27th, 2014, 08:09 PM
Ignition switch. Not sure what the loud thud was. Unscrew your dash cluster and investigate.
http://www.defendersource.com/forum/...ad.php?t=26677
Old April 27th, 2014, 08:12 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Well, you can always lead a hot to the starter to see if it is the starter-- they typically don't fail that way, but it is possible-- simple to rule out. I'd lean toward switch first though since you already have to dig into it.
Old April 28th, 2014, 12:06 AM
350rangerover
3
If the motor was running before i would look at the starter solenoid next if the ignition wasn't the problem.
Old May 3rd, 2014, 08:45 AM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
It was the switch. Thanks for posting that link Josh. Very easy after slotting the shear bolts!
Old May 3rd, 2014, 08:59 AM
Glad the fix was easy and cheap enough. Any idea what the loud thud was yet?
Total loss of power - now won't crank dnp Defender Technical Discussions 7 February 17th, 2007 10:23 PM
Need Crank Pulley RedRhinoProducts Wanted 0 November 16th, 2005 11:41 AM
Crank shaft pulley Mike Hippert Defender Technical Discussions 13 April 3rd, 2005 01:13 AM
More aftermarket parts finds, crank scrapers and windage trays! Hans Misc. Chit-Chat 0 February 28th, 2005 03:49 PM
'97 SW window handle crank J4hand Defender Technical Discussions 2 August 8th, 2004 08:51 PM
