No Pass Emissions causes - Defender Source
Old December 13th, 2012, 09:01 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Is it a large concern that a 90 for sale cannot pass emissions in it's current state? Is this a simple fix, for example maybe a O2 sensor, CC, or needs new exhaust? Colorado is strict as hell on cars passing so I figured I would see if anyone has an issue with their 90 not passing and the possible reasons...talking NAS here...
1994 Defender 90
2006 LR3 SE
1996 Discovery I (sold)
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
2006 LR3 SE (sold)
Old December 13th, 2012, 09:17 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
what year 97 or 95/94 different trucks
usually o2's and a tune up
Surf90's Avatar
Surf90
C.S.
1989 Defender 110 200tdi
Just buy one that passes in CA. It'll pass everywhere.
-- I grew up in Colorado and lived for 7 ish years in Boulder. Even while living in Boulder I would register my cars in Ft. Collins at my folks house because at the time Larimer county didn't require emission inspections.
Old December 13th, 2012, 09:35 PM
Depends. 97 will flunk for any check engine light. 93-95 have to have a sniffer and frankly because they can't load test them, it will pass even without cats if it is decent tune.
In any case, they can usually be made to pass easy enough.
Old December 13th, 2012, 09:38 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
One in question is a 94 if that helps...most likely a tune up I figure.
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old December 13th, 2012, 09:58 PM
Usually a reason is given in the fail report. The owner should have that report available and provide the information to you.
Old December 14th, 2012, 12:31 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Only time my 94 has fail was when the crack in the y pipe got bad enough to finally smell in the cab.
Jimmy Buffett
Old December 14th, 2012, 12:39 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Thanks for the replies, I will ask seller for reasons why it failed. I can't imagine it wouldn't ever pass emissions if everything was tuned up/fixed...
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old December 14th, 2012, 12:42 PM
Yup. Tune up and oil change ... or just run it on the machine when the engine is warm, not cold.
Mine would always pass with near zero emissions numbers.
Old December 14th, 2012, 12:52 PM
aaronlam's Avatar
aaronlam
aaron lam
1997 Alpine White D90 SW #2212
I've been told time and time again that these D90's emission systems (when working properly) are tighter than needed to be.
Mine failed for stupid reasons... bad 02 sensor and the PO had removed the CEL bulb so had no idea. Then the shop took it again for check when I had removed the odo for fix... um yeah... can't verify mileage = fail.
Rear Bestop pass. window UpnOver Wanted 0 August 13th, 2005 02:26 PM
Emissions question Rod Hayward Defender Technical Discussions 5 March 2nd, 2005 03:44 PM
Dreaded Emissions Test and P1317- ABS Rough Road d90xj Defender Technical Discussions 3 October 24th, 2004 01:23 PM
Just failed an emissions test, suggestions? Hans Defender Technical Discussions 6 October 11th, 2004 12:12 AM
Need 10 Spline Pass. Side Front Axel... h2eater Wanted 3 August 14th, 2004 09:57 PM
