No Parts Available - Defender Source
Old August 24th, 2011, 10:35 PM
The Wizard's Avatar
The Wizard
Douglas Wozny
1994/ Defender 90 #500
No Parts Available
The check engine light came on. So, I took it down to the shop to see what was up with that. They found that there was a leak from the vent valve at the fuel tank and the cannister will not hold a vacuum. The real problem is they can't get the parts to fix it. Land Rover does not make them anymore. The shop checked the obvious places with not lock. Anyone know of a source that has the parts available or a "work around' to fix the problem. The problem does not effect the vehicle's performance and is an air pollution system.
The Wizard
To paraphase "Oddball" (Donald Sutlerland, "Kelly's Heros", 1970) "I only drive 'em, I don't know how to fix them."
1994 Defender 90 No. 500
Old August 25th, 2011, 10:56 AM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Is it the tubing going from the top of the tank to the canister? If so, just go and get some feet of fuel line and new clamps. You'll be good to go. You'll have to drop the tank to do everything correctly.
You shouldnt need any of the LR parts for that stuff.
Old August 25th, 2011, 11:16 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Good thing given what it costs at RN.
Old August 25th, 2011, 01:09 PM
97-D90-736
Nick Vogel
All of the lines except for the fuel were rotted and cracked. I replace all of them including the fuel fill line for less than 50 bucks.
Fuel line is fuel line....you know?
Old August 25th, 2011, 03:28 PM
The Wizard's Avatar
The Wizard
Douglas Wozny
It is the cannister itself that has the leak in it.
The Wizard
Old August 25th, 2011, 03:40 PM
Can the crack not be repaired? I have a little plastic welding kit that is effectively a soldering iron with a way to feed plastic rods through it to fill cracks.
What's it worth to you? I traded a bikini top for one of these not that long ago and I really just got it "just in case" since they are NLA and I didn't need the bikini top. I honestly don't know if I made a decent trade or not.
Originally Posted by pendy
I'm here for the D's
Old August 25th, 2011, 06:34 PM
jetmech's Avatar
jetmech
Dave McHenry
1984 Landrover 90 CSW
I have a vent valve if you need it we can work out the price.
Old August 25th, 2011, 06:57 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Not really. You'd need line rated for fuel injection (at least 60psi to be safe) and ethanol compatible. Not that this has anything to do with the thread....but worth consideration.
Matt Browne
Old August 26th, 2011, 08:11 AM
Surely other V8 rovers (and other cars) have a similar canister as well? If you are not trying to keep it stock, there have to be alternatives.
part, parts
4.0 to 4.6 parts? gtg067i Defender Technical Discussions 6 September 11th, 2010 08:40 AM
D-90 1994 parts and Disco 2 parts JAD For Sale - Parts 10 August 1st, 2006 03:00 PM
FS: OldMan EMU & RoverTym parts RoverWrecks For Sale - Parts 14 June 12th, 2005 10:05 AM
Help empty my garage! Ton's of parts.. RedRhinoProducts For Sale - Parts 12 June 1st, 2005 09:24 AM
spring cleaning- D90 parts Chris Cox For Sale - Parts 13 April 4th, 2005 01:51 AM
