No Joy Disco Starting - Defender Source
Old February 12th, 2013, 01:40 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
'96 Disco. I turn the key, the dash lights come on, and all I get is nothing. I can't tell if the solenoid is clicking or not. Supposedly the starter was replaced last month with a used one.
I will add that the no-start issue is extremely sporadic and not tied to being cold or hot. Sometimes there will be a split-second delay before the starter triggers. I have already replaced the battery ground and cleaned the connections, battery tests good.
Does the D1 have any other gizmos that affect cranking, like a relay? Could the crank position sensor be a culprit or does that only affect actual starting?
Cheers in advance!
Semper Fi!
Old February 12th, 2013, 01:41 PM
giftshopduane
Chris luciano
72 Series 3 88"
Look at the terminal on the starter could be loose.
Old February 12th, 2013, 01:45 PM
Wolf Fabrication
Sterling Archer
'08 D3
Did that, it's beuno.
Semper Fi!
Old February 12th, 2013, 01:53 PM
giftshopduane
Chris luciano
72 Series 3 88"
Good.. crank sensor will affect starting not cranking. You replaced the starter with a used unit could be that. There shouldn't be anything else in line causing issues.. Usually the ignition switch holds up quite well.. I know you cleaned the contacts, did you take a look at the small trigger wire on the starter relay, beyond just the terminal, they corrode and can cause lazy starting.
Old February 12th, 2013, 01:57 PM
HeloBubba's Avatar
HeloBubba
Chris Murphy
'89 127 (D130), '16 LR4
I had a similar issue on my 97 D90 about two years ago and it ended up just being the main ground to the block right by the starter. A little corrosion had built up between the cable and the connection, and then during a big rain storm it was pushed over the no-go line. I shut it off at a restaurant and came out to a dead car.
After getting it towed home that night, I spent the next day checking the obvious list of possible stuff, and eventually all it took was loosening, jiggling the connections down there, and retightening it all up. It then fired right up without issue. I went back and cleaned up the connection and have never had a problem since. Hopefully it'll be this simple for you as well, but without the wasted troubleshooting I dealt with!
Murph
Chris Murphy
'89 D130SW
'86 D110 3-door
'89 D110SW
'16 LR4
Former:
'97 D90SW - SOLD SEP '14
'94 D90ST - SOLD MAY '13
D90s sold while assigned overseas. You're welcome America!
'06 Range Rover Sport Supercharged
'8X FankenRover D100
Old February 12th, 2013, 01:58 PM
Wolf Fabrication
Sterling Archer
'08 D3
I just got the truck and was told the starter was replaced with a used one - not sure why someone would go through the trouble and not put in a new one considering they arn't expensive...
I'll check that wire.
Semper Fi!
Old February 12th, 2013, 03:09 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Used starters are $30, new ones are $200. That's why. And starters take about five minutes to swap once you remove that pesky heat shield and install normal hex head bolts.
Have you bench tested the starter?
Old February 12th, 2013, 06:30 PM
Wolf Fabrication
Sterling Archer
'08 D3
New starters are $150, rebuilt are $110. For something as critical as a starter it seems like a dumb thing to try and save $$ on.
I'll bet you a case of beer you can't change a starter in 5 minutes. And doing it on a muddy trail sounds like even more fun.
Semper Fi!
Old February 12th, 2013, 07:15 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
If the starter is OK (have you tried to test it yet?) it could be the ignition switch. Turn the key to the on position, and use a jumper wire to engage the solenoid using power from the terminal where the positive cable attaches.
You may need one of these
Old February 13th, 2013, 11:06 AM
Ha! Was that a short joke?
Old February 13th, 2013, 11:36 AM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
FWIW about 10% of the time my disco only starts in neutral
Old February 13th, 2013, 12:17 PM
Wolf Fabrication
Sterling Archer
'08 D3
It seems to be pretty intermittent. For the most part it won't start on the first turn of the key, but will on the second. I can hear what I think is the starter solenoid clicking.
Does this sound like an ignition switch issue?
I do still need to crawl under the truck again and double check the starter ground...
Semper Fi!
Old February 13th, 2013, 01:37 PM
giftshopduane
Chris luciano
72 Series 3 88"
Honestly it sounds like the starter, even of the solenoid clicks the contacts inside could be junk, or the brushes are going away.
C
Old February 18th, 2013, 06:04 PM
Wolf Fabrication
Sterling Archer
'08 D3
C
This still has me baffled as it appears to be ignition switch related. It's still intermittent, but today most of the time it wouldn't start on the first key turn, and it appears that putting it in neutral helps.
The SRS light is on if that even remotely has anything to do with it.
Semper Fi!
Old February 18th, 2013, 07:02 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
check switch that detects park......been there done that...easy fix.
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old February 18th, 2013, 07:10 PM
Wolf Fabrication
Sterling Archer
'08 D3
Where is located? In the console itself?
Semper Fi!
Old February 19th, 2013, 05:46 AM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
PM sent.
Rick
95 P38 "Gus" RIP
03 D2 SE "Fred"
Old March 21st, 2013, 08:49 AM
Wolf Fabrication
Sterling Archer
'08 D3
So after a short period of no issues, something finally died. The truck no longer starts and all I get is the audible click of the solenoid. I tried jumping it just in case, but that didn't work. Tried it in N as well, and rolling the truck back and forth.
When everything was working, I would turn the key and hold it for what seems a split second longer than usual and the starter would turn.
I did run a secondary ground and replaced the main ground.
Starter has not been pulled and tested, but that is next. Any other ideas?
Semper Fi!
Old March 21st, 2013, 09:05 AM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
Every once in a great while, mine does this. It seems like I turn the key to position 2, dash lights up and chime goes off...then wait for a couple of seconds....there is a click and fuel pump runs..then turn to start position. It will not start if I jump in...turn the key to start right away. I guess it has to think if about if it wants to run today or not. If you need a hand with it give a call....
Rick
95 P38 "Gus" RIP
03 D2 SE "Fred"
Old March 21st, 2013, 09:21 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
You did not say if you tried to put 12V directly to the starter (your have two wires to the starter: thick 12V permanent + smaller trigger 12V coming through ignition, park, etc; put 12V directly on the smaller trigger pole). You should be able to do that without taking anything apart.
MonLand
1995 D90 NAS
1996 Discovery NAS
disco, start, starting
D-90 1994 parts and Disco 2 parts JAD For Sale - Parts 10 August 1st, 2006 03:00 PM
01 Disco! TwisteD90 For Sale - Vehicles 4 February 7th, 2006 01:38 PM
Help empty my garage! Ton's of parts.. RedRhinoProducts For Sale - Parts 12 June 1st, 2005 09:24 AM
Garage Sale - 2ea LT-230, Hood.... RedRhinoProducts For Sale - Parts 10 November 22nd, 2004 08:12 AM
97 trans/xfer into 95 Disco boxerhips Defender Technical Discussions 4 June 10th, 2004 01:08 AM
» Defender Registry
90 V8
KeithD
White
KGH
Add your Defender
