No Joy Disco Starting - Page 2 - Defender Source
Old March 21st, 2013, 10:09 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
check the crank signal at the starter .... i might just be an ignition switch you can get just the electrical part for it .. they were bad since day one
also check the under hood fuse panel for corrosion that's a possibility but little rarer on a d1
if no luck it also might be the security module went bad looks like the pic mounted behind glove box ..you would also need someone with a t4 to re-learn security code
http://landroverparts.roversnorth.co...OVERY-I&key=it
No Mall crawler here
Old March 21st, 2013, 11:02 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
So maybe I'm confused, I would think that if there is something blocking the start signal or if it was the ignition switch that the solenoid wouldn't click.
I still need to tow the truck home.
Semper Fi!
Old March 21st, 2013, 11:28 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
first and foremost ..."IT'S A ROVER".......check for a signal at the starter first... if the starter solenoid is clicking then your starter is bad or your battery is dead .... if the module is clicking it might be faulty and might just need to be re-learned to send the proper signal .. the truck might have gone into immobilizer
Old March 21st, 2013, 12:05 PM
Did you try shorting the starter to see if it turns?
Do you hear the fuel pump run when you cycle the key?
My ex's 96 disco had an ignition switch failure and it did this.
Old March 21st, 2013, 01:02 PM
Wolf Fabrication
Sterling Archer
'08 D3
Haven't shorted the starter yet, it's such a small space, but I'll try that next....
Fuel pump runs and solenoid clicks which leads me away from the ignition switch.
Either way, my next troubleshooting take is to attack the starter.
Semper Fi!
Old March 29th, 2013, 07:48 PM
Wolf Fabrication
Sterling Archer
'08 D3
FYI, for everyone's education, this ended up being the starter. Popped a new one in and it fired right up.
Semper Fi!
Old March 30th, 2013, 04:39 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
The SRS light is on if that even remotely has anything to do with it.
Now that you have the starter figured out... SRS light can be a variety of issues. If you don't want airbags, remove the fuse, light, the SRS wiring.
If you want to retain airbags, you will need the light cleared (I.e. issue fixed) to make it through VA inspection. Low battery (less than 10V?) will trigger the fault. Only way to clear it is through a T4 (or equivalent; $80 at the dealership... Look for a friend!). I was also told that airbags should be replaced every 10 years (and no, I have not done it).
There is a connector (where?) that gets wet/corroded that can lead to not be able to clear the faults (no idea where it is).
Anyway, just food for thought!
MonLand
1995 D90 NAS
1996 Discovery NAS
Old March 30th, 2013, 07:47 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
Srs .....here's a tip ..disconnect the srs wires under the seats put dielectric grease in the connector re connect and see if the light goes out ....
disco, start, starting
D-90 1994 parts and Disco 2 parts JAD For Sale - Parts 10 August 1st, 2006 03:00 PM
01 Disco! TwisteD90 For Sale - Vehicles 4 February 7th, 2006 01:38 PM
Help empty my garage! Ton's of parts.. RedRhinoProducts For Sale - Parts 12 June 1st, 2005 09:24 AM
Garage Sale - 2ea LT-230, Hood.... RedRhinoProducts For Sale - Parts 10 November 22nd, 2004 08:12 AM
97 trans/xfer into 95 Disco boxerhips Defender Technical Discussions 4 June 10th, 2004 01:08 AM
