No hi-beams & dash lites get dim - Defender Source
Old December 20th, 2010, 04:39 PM
peachyracer's Avatar
peachyracer
Peter Stolz
My wifes '94 D90 POE #1500
Everything runs fine but when I switch on the high beams, all headlights go out. The dash lights also get dimmer and I can hear a belt squeal...assumption is alternator.
This seemed to happen after the ignition switch was replaced, but not sure because don't often use high beams or horn.
Headlight switch problem, ground problem?
Pete
Pete
Old December 20th, 2010, 04:46 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
I would say it sounds like a ground issue and not the switch. You mention the lights come on fine and only go out once you put on the high beams?
Old December 20th, 2010, 05:12 PM
peachyracer
Peter Stolz
Right. The headlight low beams work fine, and when I flick the brights on, the low beams go off but the high beams don't come on. At that time, there seems to be an increase in electrical draw because the dash light get dimmer (dimmer than usual I should say ).
(Also the horn was just a blown fuse.)
------ Follow up post added December 20th, 2010 05:26 PM ------
The problem happens when I push the brights lever away from me (toward the front of the truck), but when I pull the brights lever toward me, both the low beams and high beams go on and the dash lights don't get dimmer.
Old December 21st, 2010, 02:02 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Sounds like the "Magic" light wand has a short in it. Pull the cowl and inspect the contacts on the wand for where the smoke got let out. If one/some of the contacts are grounded then it will put a real heavy load on the alternator and electrical system. Don't catch fire.
Old December 21st, 2010, 04:56 PM
peachyracer
Peter Stolz
Well, thankfully nothing has been smoking. I'll check the contacts tonight.
dash
Dash Rotted Out, Had to Fix It JimC Misc. Chit-Chat 7 February 6th, 2009 03:20 PM
Dim dash lighting chris snell Defender Technical Discussions 9 January 14th, 2009 07:22 PM
New Defender Dash parts TDI Guy For Sale - Parts 1 April 3rd, 2005 10:58 AM
dash gauge lights very dim Marc Weinstein Defender Technical Discussions 15 October 17th, 2004 01:49 PM
1997 Dash panel - what's there? ronward Defender Technical Discussions 6 April 26th, 2004 05:47 PM
