NO Headlights - Fuses All Good/MOD pls Delete - Defender Source
Old October 10th, 2009, 11:45 AM
BlackDog
A. Fehd
95 90ST
Plugged my trailer in last weekend (four prong) and went to haul away some brush, had the headlights on for 30 seconds when the dash went dim. Pulled the lights switch off and then back into "running lights". Running lights are working in first "light" stalk position, turn signals working fine.
When I throw switch for full headlight and running lights I get nothing. All fuses are fine as are the BIG ones in the engine bay against the firewall. Truck starts/runs, etc.
What am I missing? Light relay? Thanks ahead of time.
Apologies here - broke sticky rule #1 and didnt search. MOD please delete. Same symptoms as others had, burned my small switch up apparently.
MOD please delete.
ht, lights, mod
Low Beam Headlights Quit JimC Defender Technical Discussions 7 January 29th, 2006 07:54 PM
Headlights - switch problem? mgrgpg Defender Technical Discussions 3 December 14th, 2005 03:42 PM
Yaaaaaaaaaaaarg! Frigging headlights solihul Defender Technical Discussions 2 June 23rd, 2005 10:29 PM
Help - My 90's headlights don't work solihul Defender Technical Discussions 5 May 20th, 2005 01:27 AM
97 D-90 SW blowing fuel pump fuses intermittantly BarryO Defender Technical Discussions 9 July 20th, 2004 03:07 PM
