No headlights - Defender Source
Old June 7th, 2013, 10:49 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
No headlights
When I switch to parking lights, they come on. Why I switch to headlights, nothing. Even the dash lights shut off. If I pull back for bright beams, lights work. Any thoughts? Fuse?
1994 Defender 90
2006 LR3 SE
1996 Discovery I (sold)
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
2006 LR3 SE (sold)
Old June 7th, 2013, 10:56 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Thanks man. Is the switch easy to remove and replace? I assume I can buy this from Rovers North?
Edit--
Looks like I found the switch...I will order one and it looks pretty easy to install.
http://landroverparts.roversnorth.co...=PLE497&type=0
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old June 7th, 2013, 11:33 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Before I buy the switch in the link above, can someone confirm that this is the right one? I see there is another similar switch with a longer wiring harness seen here...which one is right? Big price difference...
http://landroverparts.roversnorth.co...x?code=PRC3430
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old June 7th, 2013, 11:48 PM
bjf's Avatar
bjf
barry f
94 ST #395
You need your vin number to determine which one you need.
Old June 7th, 2013, 11:52 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
There are a few different connectors depending on harness (VIN/Engine/date)
We have three versions in the warehouse. Snap a photo of the connector you have.
Old June 7th, 2013, 11:56 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Thanks, I would have never guessed there would have been different ones. I will snap pic tomorrow when I remove the lower area of the steering column. Or I can provide VIN to save the trouble.
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old June 8th, 2013, 12:03 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
You are going to pull the lower steering column cover off to swap the switch, so you may as well be certain what you are after...
I'll be in the shop in the AM if you need to verify part numbers.
Old June 8th, 2013, 12:20 AM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Sounds good ill get a pic over to you in AM. PM me your number.
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old June 8th, 2013, 05:12 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Ordered a brand new switch, thanks for the offer Brian. Now that I have been fooling around with the plastic area under the steering column, the steering wheel doesn't move as freely. I am sure I didn't angle something back correctly under there...
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old June 8th, 2013, 08:35 PM
Install the relay kit lest you melt the new one too.
Old June 8th, 2013, 09:41 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Point me to that harness.
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old June 8th, 2013, 09:50 PM
Scroll down
https://www.expeditionexchange.com/arb/
Old June 11th, 2013, 11:31 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Just curious: how does the ARB setup differs from this one?
http://www.ebay.com/itm/CERAMIC-H4-H...#ht_5222wt_898
It's very straight forward and assuming (that could be "it"! ) that the wires to the battery are long enough, this would work perfectly, right? [This is what I had envisioned making, but at that price, I'd likely go "buy" vs. "build"].
MonLand
1995 D90 NAS
1996 Discovery NAS
Low Beam Headlights Quit JimC Defender Technical Discussions 7 January 29th, 2006 07:54 PM
installing Hella headlights oldscratchggf Defender Technical Discussions 5 December 25th, 2005 10:16 PM
Headlights - switch problem? mgrgpg Defender Technical Discussions 3 December 14th, 2005 03:42 PM
Yaaaaaaaaaaaarg! Frigging headlights solihul Defender Technical Discussions 2 June 23rd, 2005 10:29 PM
Seats and headlights Disco_Stu For Sale - Parts 7 October 26th, 2004 07:21 PM
