No communication to ECU - Defender Source
Old April 28th, 2010, 03:07 PM
nomadic90's Avatar
nomadic90
Ryan Quandt
97 defender 90
Defender 90 1997 S.W.
I have no communication to ECU (under the hood) when the ABS ECU (under the seat) is connected. When I disconnect the ABS ECU it restores communication back to the OBDII plug.
The following is what I have done with no luck yet.
- New ECU installed (under the hood) and reprogrammed and checked out from dealer.
- New ABS ECU installed (the one under the seat)
- Disconnected all ABS (rough road) sensors from ecu to see if that would restore communication.
- Checked continuity of all wiring going from ECU to diagnostic plug and back to ABS ECU.
- Checked all fuses
- Checked grounds
- Checked 12 volt leads
I thought I would have found the problem by now, Iím running out of ideas!!!!
Old April 28th, 2010, 03:10 PM
Do you have an aftermarket radio installed?
Old April 28th, 2010, 03:51 PM
nomadic90's Avatar
nomadic90
Ryan Quandt
97 defender 90
Yes but I didn't use any of the amp wiring that was down there. I did recently install a flat screen on the dash with the mud uk kit. Do you think something got crossed?
Old April 28th, 2010, 04:44 PM
I am not sure if it is the same issue you are having, but ECR had a post on a similar issue caused by a stereo install a while back. Search for that post.
Old April 28th, 2010, 05:15 PM
nomadic90's Avatar
nomadic90
Ryan Quandt
97 defender 90
Awesome I will search for it! You just pointed me in the right direction. I went out and disconnected the stereo from the power plug under the center cubby console and sure enough it restored communication! I just have to figure out what the heck happened. Thank you very much!!!!
I just wish I swallowed my pride and asked you first.......another lesson learned.
Thanks again,
Ryan
Old April 28th, 2010, 05:42 PM
No problem.
Ask D-90.com should be the first step in any repair procedure. You probably spent untold 100s if not 1000s for what is a simple fix. ECR explained what wires get crossed in his post.
Ron
ecu
Speed Sensor and ECU Issues DJ Menasco Defender Technical Discussions 14 February 16th, 2006 08:45 PM
Interface on '94 ECU (OBD-I?) jaherring Defender Technical Discussions 10 October 11th, 2005 10:06 PM
ECU readout cbass Defender Technical Discussions 15 September 17th, 2005 10:05 PM
Where did you put your ECU jcasteel Defender Technical Discussions 6 January 12th, 2005 11:31 AM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
