No brake lights, turn signals, temp or fuel gauge. - Defender Source
Old August 3rd, 2010, 12:25 PM
John T
John Perchorowicz
95/D90
On a D90 '95, I used a winch with the engine running. The following day I noticed these problems (no brake lights, turn signals, temp or fuel gauge) existed. Unsure if there is cause and effect here or some other, unrelated problem. Brake light (10 amp) fuse was blown. New brake light fuse blows as well when the ignition is switched on. Are these problems related? Any thoughts or easy hints on where to look to track down the source (of a short?) before I turn it over to the shop?
Old August 3rd, 2010, 12:54 PM
16kpsi's Avatar
16kpsi
Tony Lawson
1986 D110 ex-200tdi to be 6BT
where'd you use that wrench?
brake, fuel, ht, lights, signal
Fuel gauge - no reading JackW Defender Technical Discussions 2 October 11th, 2005 03:50 PM
Help wth Fuel Gauge (that works sometimes) ToyCrusher Defender Technical Discussions 14 October 20th, 2004 08:43 PM
Temp Gauge dbwitt Defender Technical Discussions 5 March 18th, 2004 08:14 PM
Temp gauge on H perminently ron Defender Technical Discussions 1 December 8th, 2003 05:27 PM
