Nitrogen in tires - Defender Source
Old August 4th, 2006, 08:13 AM
Paul Davis's Avatar
Paul Davis
Paul Davis
97 ST
Nitrogen in tires
Does anyone use nitrogen gas in your tires instead of CO2 or air?
Old August 4th, 2006, 08:21 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Oh for the love, here we go...
Old August 4th, 2006, 08:25 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I use approximately 79%
Old August 4th, 2006, 09:00 AM
Monkeyboy
Guest
Posts: n/a
Pop got new tires on the Volvo in the Spring and was all excited that he got N and green valve stem caps --- what can I say, he's a retired engineer
Clearly, there has been no difference in any aspect of the vehicle's operation ... except the cool green valve stem caps
KAA
Old August 4th, 2006, 11:05 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I use helium.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old August 4th, 2006, 11:10 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I fart in them, that way I know if I have a slow leak.
Old August 4th, 2006, 11:33 AM
roverboy's Avatar
roverboy
Thomas
Booger
Dave Souza has abandoned any sort of gas in his tires altogether. I think his swampers are full of Equal.
"There is absolutely no excuse for the way I'm about to act."
Old August 4th, 2006, 03:32 PM
Eric_S
Eric
'97 D-90 ST #1507
Good one Dave!
I mix in 20% oxygen and the remaining 1% - argon, carbon dioxide & neon.
Old August 4th, 2006, 03:54 PM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
why would you want to air is free
Old August 4th, 2006, 04:00 PM
robisonservice
John Robison
2008 Supercharged Range Rover
Yes, we do on collector cars. Oxygen rots the rubber of a tire. Filling a tire with nitrogen will prevent damage from internal oxidation which happens with regular air, or co2. On a car that runs 15k a year on highways that won't matter because the tires will wear out before they oxidize.
But collector cars can hold a set of tires 10 years or more and nitrogen will make a big difference. We believe the liklihood of sudden failure is markedly reduced.
That's why you should consider it off-road.
The only drawback is that your powertank setup has less capacity. The regulators can be adapted for co2 or nitrogen
Old August 4th, 2006, 04:16 PM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
the outside of the tyre is exposed to oxygen and sunlight both rot the rubber and every failure I have had off road has been due to physical damage to the tyre from rocks, buried clay pipes etc etc
Old August 4th, 2006, 05:11 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
(Paul Davis.... not from Rocky Point, NY are you?)
Like Mr Robison mentioned, there are valid reasons for Nitrogen in the tires, and for the reasons he described it is a good idea. But the vast majority of us that drive our trucks regularly proabably won't see much benefit as the tires wear out from normal use.
If you are thinking of using compressed nitrogen in place of a CO2 tank for fills in the field, then you might want to reconsider. Even the high pressure paintball tanks in the 3000psi to 4500psi range won't hold much air when it comes to filling tires. CO2 being dual state will have about 80% or more of the tank filled with liquid CO2 when full, and will get you a huge amount more air out of the hose between fills with the same size tank.
For an on-truck air source, stick with either a CO2 tank or a compressor for the best utility.
-Hans
My oil line fix
My 100k stopped odometer fix
Old August 4th, 2006, 05:44 PM
robisonservice
John Robison
-Hans
Hans, you have to decide how long your tires will last. If you think they will last 7-8 years use nitrogen.
The second question, which I did not mention before, is one of environmental responsibility. We should all be working to curb emission of greenhouse gases, of which co2 is one of the biggest offenders. Nitrogen is not a greenhouse gas.
I use nitrogen for the reasons above.
Old August 4th, 2006, 06:00 PM
Paul Davis's Avatar
Paul Davis
Paul Davis
97 ST
I suppose I am way out of touch. I only ask because I heard a news story and have no experience with Nitrogen nor have I heard of anyone using it in the group I wheel with. I should have known it was an outdated topic for this forum.
Hans, no I am from all over the south and southeast, but no NY.
Thanks for the responses.
Old August 4th, 2006, 06:39 PM
Hans's Avatar
Hans
Hans Haase
This is true John, and typically I get about 5 years or less on my tires, so for me the Nitrogen isn't going to be of any benefit. I'm probably best sticking with a compressor like I've always done.
I do wish that I could find more information from CO2 providers regarding how they get it. But it's not something that is easy to find. If it's reclaimed Co2, which is taken from the air, then you're not contributing anything as it already exists. But if it's drilled from the ground, or generated biologically like most food service gas is, then it's definitely bad.
-Hans
My oil line fix
Old August 4th, 2006, 08:19 PM
Monkeyboy
Guest
Posts: n/a
Huh .. no smarty pants comments from me ... this time
I imagine that's why the ten year old tires that might have run 6k miles on Julie's Mazda are leaking ?
KAA
Old August 4th, 2006, 09:13 PM
tkavan01's Avatar
tkavan01
Trevor K
94 d90 #1304
KAA
i bought a 1992 legend in 2003 that had 12k on it, the original tires fell apart as we loaded it on the two truck... it had been started on a weekly basis by the next door neighbor, but had not moved in 5 years.
tire, tires
Tires: an odessy souza Misc. Chit-Chat 37 December 14th, 2009 05:57 AM
Tires, Tires, Tires Joe P Misc. Chit-Chat 28 August 9th, 2005 09:58 PM
Trade these off-road tires for on-road tires wicks For Sale - Parts 12 April 5th, 2005 01:21 AM
4 BF Goodrich Mud Tires Jeremy Keith For Sale - Parts 5 March 3rd, 2005 07:09 PM
BFG AT Ko tires for sale Seriesman For Sale - Parts 6 August 18th, 2004 11:09 PM
