Newer one-piece door: card removal - Defender Source
Old June 17th, 2013, 08:07 PM
Talleyrand's Avatar
Talleyrand
1998 Defender 110 CSW 300Tdi
Hi guys,
I need to remove the door cards from my newer type one-piece steel doors. Any workshop diagrams out there, or guides on how to remove the cards without breaking the clips? I have the old workshop manuals but they only apply to the older type of two-piece doors that had aluminium skins.
Thanks!
Old June 17th, 2013, 08:48 PM
Jbullis's Avatar
Jbullis
Jason Bullis
1994 NAS 90 #1810, 2006 LR3
http://www.defendersource.com/forum/...ead.php?t=4087
Old June 18th, 2013, 12:01 AM
Talleyrand's Avatar
Talleyrand
Hi Jason,
Not a bad link but that is for the old type doors like what I am taking off, that is what my manuals also cover. So I still need someone to point me in the right direction on the new, Puma type doors.
Cheers,
Old June 18th, 2013, 10:50 AM
It's almost exactly the same, press studs are in slightly different locations iirc. I like to use one of those screwdriver-handled pry bars covered with tape. I just work it gently and have had good luck.
Old June 18th, 2013, 11:02 AM
If you break one of the fir tree mounts on the door card you can replace them with a metal tack that you glue and tap into place .. at least you could on the earlier type ... i'm pretty sure the later type is the same.
last piece for sale: 4 mastercraft harnesses NASD90 For Sale - Parts 3 December 9th, 2005 06:53 AM
Part # Question - Trim Piece fleabus Defender Technical Discussions 6 July 5th, 2005 02:45 PM
D90 wgn - Automatic Shifter T- Handle Removal Kimos Defender Technical Discussions 22 January 18th, 2005 07:05 PM
one piece hard top? ONDROX Defender Technical Discussions 4 November 22nd, 2004 08:21 AM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
