Newer LT-230 in older rig... - Defender Source
Old July 29th, 2004, 05:30 PM
h2eater
Jason Michaels
RRC '92
Unhappy Newer LT-230 in older rig...
Hey there, I am trying to fit a newer style LT-230 [with the 3 electric plugs/fittings] to an older Rangie Classic. I don't want to fit it until I know for sure what to do with those three connections. Someone said it won't work period unless I "modify" them. Any help would be appreciated!
Thanks for the board space!
Jason Michaels
904-662-1414
"Don't take life too seriously, it's not like
your going to make it our alive..."
Old July 29th, 2004, 06:42 PM
Hey Jason, What is the LT230 out of? Take a look here
http://www.pirate4x4.com/forum/showthread.php?t=240890
http://www.pirate4x4.com/forum/showpost.php?p=795849
Old July 29th, 2004, 07:13 PM
h2eater
Jason Michaels
RRC '92
The LT is out of a 94ish D1... Thanks for the notes on Pirate though...
Jason Michaels
904-662-1414
Old July 29th, 2004, 10:20 PM
Take the top solinoid thing off and remove the plunger thing from inside. All will be good. You should not need wires on a LT230 though you can hook up the diff lock warning light if you like, I find it helpful.
If it is 94 it should have the short input and be ok with an old RRC if it is newer you will need the 3in output for the ZF.
Ron
Old July 30th, 2004, 07:29 AM
h2eater
Jason Michaels
RRC '92
Talking
10/4, thanks for the advice Ron, I will let you know how I fair with it!
Jason Michaels
904-662-1414
Old July 30th, 2004, 05:39 PM
h2eater
Jason Michaels
RRC '92
Explain the solehnoid...
Ron,
Is the solenoid under the cap with 4 smaller bolts or the one with 3 larger bolts? I got the plate off the "top" that was help by 4 small bolts and all I see is the inside of cylinder cant figure out anything from here...
Jason Michaels
904-662-1414
Old July 30th, 2004, 06:41 PM
The one on the very top. Once you take it off the inner cylinder can be removed. Just grab the part with the plunger and pull, the whole inner thing will come out. Then stick the cap back on and seal it up. (you have to use a bit extra where the wires go in.
The three bolt one in front does not need to have anything done to it.
Ron
Old July 30th, 2004, 06:44 PM
h2eater
Jason Michaels
RRC '92
Never mind, I closed my eyes and hit it with a big hammer... I also had to swap over one of the output housings b/c the new tbox didn't have holes for the brackets... Got it now! Thanks!
Jason Michaels
904-662-1414
Old July 30th, 2004, 06:57 PM
"I closed my eyes and hit it with a big hammer"
It must be my telepathic connection with you.
Ron
Old July 30th, 2004, 08:07 PM
h2eater
Jason Michaels
RRC '92
Hey Ron,
It must be that evil twisted lucas connection we all have... Do you get up in the middle of the night and bow to your rover on a full moon as well?
Jason Michaels
904-662-1414
LT 230 Transfer Case WLDKGDM Wanted 1 June 16th, 2008 05:32 PM
Wanted E brake drum for and lt 230 TDI Guy Wanted 3 November 10th, 2007 01:45 PM
Older Cage On Newer Supports Baldewin Defender Technical Discussions 3 December 30th, 2006 08:41 PM
Rebuilt or new LT 230 TC or best reference for prices... dmarchand Wanted 2 April 5th, 2004 06:17 PM
Tow Rig survey - sort of.... tbmcneill Misc. Chit-Chat 38 January 7th, 2004 11:38 AM
