Newbie Winch Question - Defender Source
Old November 27th, 2004, 07:47 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
Black 97 D-90ST #0605
Got the Warn XD9000i this week and want to use the long weekend to install it. I have everything on the truck, now the tough part. First the cables are too short - surprise the battery is under the seat and not the hood.
Two questions-
First - What did you do to A lengthen the cables or B replace the cables.
Second - How did you route the cables.
Joe
If the truck makes it - the trail wasn't tough enough.
If the truck doesn't make it - the truck wasn't tough enough.
Old November 27th, 2004, 08:03 PM
Hey Joe, I picked up some longer cables at West Marine, they have heavy gauge wire that is nice and flexible. I am pretty sure they have a way to splice the wires together, or you could get one of those heavy 2 prong connectors, the type they use on forklifts, warn also sells them for there receiver mount winches. That way you can use that point to hook up a pair of jumper cables using the same type of connector and not have to go into the seat compartment.
As far as running the cables, I ran them next to the frame all the way to the T-case mount, from there I ran then up into the seat box and connected them directly to the battery.
Old November 28th, 2004, 01:30 AM
BarryO
Barry O'Mahony
97 D-90 SW LE
I don't like splicing cable. The splice is a failure point (it is more likely to fail than the wire itself). Either the connection opens, or the insulation that it put on the splice shorts out (not something you want to happen on an unfused, high-amperage connection direct to the battery).
I got lengths of #1 AWG battery cable at a local NAPA. The terminal ends are not easy to put on; they're a compression fitting that must be crimped on properly. That's the only tricky point.
I ran the cables as Mike did. I'd suggest putting that black plastic wire protective tubing (i.e., the type slit along one side) over the positive cable for extra insurance.
Also, install a cut-out switch in the battery compartment. I understand a common vandalism technique in Australia is to wrap the winch cable over the top of a vehicle and attach it to the rear hitch, and use a couple of paper clips in the winch control socket to turn it on: not a pretty picture.
winch
Safari Gard winch bumper and winch m016324 For Sale - Parts 3 September 20th, 2005 09:52 PM
WARN 8274-50 Winch, THE ULTIMATE!!! RedRhinoProducts For Sale - Parts 0 September 28th, 2004 08:18 AM
newbie question re: doors and tops jaherring Defender Technical Discussions 12 July 19th, 2004 06:41 PM
Winch Bumper Question mgrgpg Defender Technical Discussions 17 February 21st, 2004 10:48 PM
Winch wiring question flippedrover Defender Technical Discussions 4 January 11th, 2004 09:20 PM
