Newbie Needs help - Defender Source
Old September 12th, 2011, 03:44 PM
jsimpson
James Simpson
1995 Defender 90
Newbie Needs help
Need new crank and balencer for my 1995 d90. Cant find anywhere. RN and AB do not have. Any suggestions? Located in CT USA. HELP please!
James
Old September 12th, 2011, 03:51 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
You need a new crankshaft and harmonic balancer?
Old September 12th, 2011, 03:57 PM
jsimpson
James Simpson
1995 Defender 90
yes
yes-exactly
------ Follow up post added September 12th, 2011 02:59 PM ------
yes. happen to have a source?
Old September 12th, 2011, 04:02 PM
kevkon's Avatar
kevkon
kevin
I assume you are rebuilding an engine from parts or had a catastrophic engine failure. I would say a junkyard/auto salvage yard would work. Or try an engine rebuild company. I think you could almost buy a TDi for what a new LR crank goes for.
Old September 12th, 2011, 04:07 PM
jsimpson
James Simpson
1995 Defender 90
Car is close to mint. Was driving fine but took to my guy for some minor work-including changing belts. When he took belts off we noticed lots of play in the the Harmonic Balancer. Took of and saw that keyway was trashed and key was almost gone. did a number to the crank as well. both need to be replaced. If I could find, they are $2000 together for parts as listed. What do I do here??!! Car has 40k miles on it-been in TX barn for 12 years.....out of my comfort zone here......Thanks Kevin
Old September 12th, 2011, 04:42 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I could probably help you out. I have a 4.0 crank and a v-belt harmonic ballancer/pulley--do you need serpentine or v-belt?
Old September 13th, 2011, 08:10 PM
Turbofan's Avatar
Turbofan
Ethan
'73 SIII/ D90 Hybrid
Call Dawson at Classic 4x4's. I know for a fact there are several used cranks (and harmonic balancers) sitting in the shop. 203-870-1022. He is in CT too!
Old September 13th, 2011, 10:41 PM
A machine shop should be able to repair the keyway.
Old September 14th, 2011, 02:42 PM
If Bill is right, I have a balancer off of a 94 that had 72k on it if you want it - you pay shipping. I don't see a keyway on it so maybe I have the wrong piece in mind. It's a heavy cylindrical piece of steel the flywheel bolts to right?
Originally Posted by pendy
I'm here for the D's
110 Newbie looking for help Marx-110 Defender Technical Discussions 20 July 7th, 2004 12:01 PM
More D90 Newbie ?'s mlw911 Say Hello! New Member Intros. 3 June 29th, 2004 06:47 AM
Newbie ST owner Cyborg Defender Technical Discussions 7 May 19th, 2004 02:11 AM
Newbie NAS ? Hammertime Defender Technical Discussions 3 January 20th, 2004 08:24 AM
