We ditched the Freeloader a couple of week back and now have a '97 SW in the drive! - to go along with the 109 & the Disco.
Our genius dealer determined (before we bought it) that the check engine light was on due to a bad ECU that continued to give the "rough road" fault.
They replaced the ECU with a new one....yep, light is still on.
Has anyone had good luck with any of the "reasonably priced" OBD II software applications? I'd really like to view the codes, fix the problem and reset the light myself.
Most auto parts shops (Checker, Kragen, Autozone) have a code reader at their parts counter. If you leave them a credit card number they let you take it out to the parking lot to read your codes. Hope that helps....
For a portable scanner I use an EQUUS INNOVA 3100. Can clear, show pending codes and reads every 5 seconds. It's not perfect: does not have a backlight so reading in the dark is difficult, but it's one of the better units out there.
For a PC based system with continous reading of several functions I use an Autotap AT3.
FYI, there is a recall campaign on this rough road sensor problem, if that is in fact your problem.
Stopped at the dealer yesterday afternoon and the tech plugs in the hand held scanner thingie.
He reads some codes, unplugs the big cable from the underseat unit pushes some buttons and says that the handheld and the in car computer "can't communicate"; sounds just like home, eh
He calls me later last night and says that LRNA tells him he needs to download new software to the vehicle. He doesn't have the software (Disc #14) on hand and we'll have to wait until it arrives in the mail.
Arthur, what recall campaign are u talking about? You have any more info on it, cuz I think I got the same problem with my check engine light keep coming back on due to a "rough road" detection.
Does anyone out there have a recommendation/experience with OBDII Code Readers that have "live data" display, that you can use with vehicle running? I have heard Equus Innova 3100 is good, but what I can find locally at Sears is the Actron Super Scanner for $279. Definitely have to get one with the live data display feature. Anyone have knowledge of Actron unit or others that work well in our Land Rovers?
I had the same issue with the Rough Road sensor tripping my Engine light. I have a OBDII scanner, which I can't think of the brand off the top of my head, that I used to clear the Engine light. The PO of my '97 SW was told by the dealer that it was a problem with the ECU, software version, etc, etc. That never cleared the problem and the PO never could get the problem fixed. It turned out that it was a bad sensor at the wheel, which I had replaced, and was not nearly as $$$ as replacing the ECU at the dealer.
KAA
A common trick is to disconnect the rough road detection ECU before connecting the T4 HTT. Most times once the rough road ECU has been removed from the loop, the T4 will then communicate.
I have seen the fault you describe develop as a result of a bad speed sensor. I have also seen that same fault give quite a headache and ultimately being traced to faulty ground to the rough road ECU.
Is this the same version for a 95? Or does someone know what that one is?
thanks,
bill
Related Threads
Defender Source Forum
1M posts
24K members
Since 2003
