Newb Door Lock Problem - Defender Source
Old April 16th, 2015, 02:01 PM
Hello all,
Received our 86 110 SW last week! Sweet!
Among many other things, noticed that we can not get the door locks to work on any of the 4 doors (have not yet looked at the rear door). It might be the same problem for all 4, so we've got that going for us, or it might be that I'm an idiot. Either way, need some helps please!
Door lock up: can use the interior and exterior door handles to open the doors no problem.
Door lock down: can use the interior and exterior door handles to open the doors no problem.
What kind of voodoo magic is this??
- brian
Old April 16th, 2015, 02:24 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
is the issue the same with the key as well or only the plunger?
Old April 16th, 2015, 02:31 PM
OK - just went outside and tried it. After fumbling with the key for a few minutes to find out which one actually goes in the door, I found the right one. Whew.
Ironically, the key works. It will in fact lock the front driver's side door; but, wait for it,...the plunger doesn't move when you use the key.
Old April 16th, 2015, 02:34 PM
sounds like one of the arms is dis-connected. start pulling it apart and fixing it ... do this before you find the 500 other things that will comprise the activities of higher priority ...
Old April 16th, 2015, 02:40 PM
Thanks Jason - I will pull it apart and give it a go.
We're prepping ourselves for the joy of the higher priority activities that are sure to follow
NPT90's Avatar
NPT90
JT
D90 óriginalé
I'd take the good with the bad, I am pretty sure my 83 lift up doors behaved the same way and I just lived with it.
Option B is take it apart, you should see the issue pretty quickly
Old April 16th, 2015, 02:47 PM
Yep, you're probably right JT. But even with the working key in the driver's door, none of the other locks are functioning
In the grand scheme of 110 ownership, this in the low priority list, but we'd like to be able to lock the truck at some point...
Old July 12th, 2015, 08:59 PM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
Just haunting old threads to work thru my 1st Defender ever issues. Sorry if I'm stating the obvious, but for fellow newbs unable to lock their latch style door locks, try rotating the key clockwise 180 degrees as in the universal modern normal scenario, but then pull the key out rather than returning the key to the original vertical postion to pull it out, which apparently simply re-unlocks it on these. My back end door works the modern way for some reason. Go figger.
Old July 12th, 2015, 10:01 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
The rods tend to shake loose and are sometimes missing the "lock" tabs which you should be able to buy at almost any auto parts place...
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
door
Newb Q: Rear Bumper Bolts xplorUtah Defender Technical Discussions 2 August 5th, 2010 11:35 AM
Newb introduction... smittycrusher Say Hello! New Member Intros. 3 July 28th, 2008 10:09 AM
Looking for a D90 soon - newb questions don Misc. Chit-Chat 18 September 28th, 2007 07:18 AM
Newb thinking about buying D90-HELP Todds112 Defender Technical Discussions 21 October 26th, 2005 09:26 PM
Newb here, pics link Tdi200 Say Hello! New Member Intros. 2 November 18th, 2004 12:35 PM
