New Wolf/NATO wheels not true? - Defender Source
Old July 15th, 2009, 11:52 PM
crobinson
Chris Robinson
97' D1
Ordered one wolf wheel from a long established major LR parts supplier. Took the wheel to my local tire to have mounted, but before mounting I had the wheel tested first to see if it was true. It had a wobble 1/4" out and in. It was mounted on the machine thru the center hole, but I got the same result mounting it on the truck resting on jack stands and in gear. The supplier was kind enough to send a replacement wheel but I got the same wobble (mount on truck no tire in gear) with the replacement wheel. Is this common? Am I being too picky?
Old July 16th, 2009, 12:53 PM
grnrvrs's Avatar
grnrvrs
Paul
88
lug centric v hub centric?
Old July 16th, 2009, 01:25 PM
Does it run true on the truck? You can check run out easy enough if you just mount the wheel to the vehicle.
Old July 16th, 2009, 01:44 PM
what are you using to measure it?
Old July 16th, 2009, 02:18 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Yes it is common. Most Rover steel rims are not 100% true.
Depending on tire and size sometimes it will input a vibration, sometimes it won't.
Email:
Old July 16th, 2009, 05:44 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
It's a rover part. Being out only a quarter inch is a miracle.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old July 17th, 2009, 02:15 AM
crobinson
Chris Robinson
97' D1
Mounted it both ways with no tire and got the same result.
Old July 17th, 2009, 08:33 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
And it is supposed to be military equipment ...
- Charles Eames
Old July 17th, 2009, 08:58 AM
ECR's Avatar
ECR
They got it right then.
Expensive parts built by the lowest bidder to a minimum standard.
Email:
Old July 19th, 2009, 07:35 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I've been taking them (Wolf wheels) to a wheel shop and getting them straightened.
Matt Browne
Old July 19th, 2009, 11:36 PM
crobinson
Chris Robinson
97' D1
What does that cost? How is it done?
Old July 20th, 2009, 06:42 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
It's a machine similar to a tyre machine that locks the wheel in place and has hydraulics to manipulate the wheel. It is $10-15 ea to do steel wheels.
They couldn't straighten the center on one of my Stazworks beadlocks though
Matt Browne
wheel, wheels
Disco II / Range Rover Wheels rvrnut110 For Sale - Parts 0 November 9th, 2005 01:51 AM
5 Allied beadlock wheels jdb3760 For Sale - Parts 3 September 20th, 2005 05:19 PM
35" BFG AT KOs and 15x7 wheels Jase For Sale - Parts 1 August 19th, 2005 05:30 PM
Stock Diff w/ True Trac James Pierce For Sale - Parts 1 August 31st, 2004 08:26 PM
MJ Lee Wheels! TwisteD90 Misc. Chit-Chat 16 February 21st, 2004 10:55 AM
