new VDO gauges sway like crazy - Defender Source
Old October 20th, 2006, 10:31 PM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
So I just did the VDO gauges... Speedo, fuel and temp. All work, all register where they are supposed to... That is if you average between where they sway. The speedo sways about 5-7 MPH in each direction (and while slowing down to a stop it stops at 5 MPH, and then just drops), the fuel gauge sways about 1/8 of a tank (1/4 tank around turns) and the temp gauge sways about 2mm each direction of 180 degrees.
Serious, wtf? This is becoming the biggest goddam headache. Any input would be appreciated, because I`m about ready to drive this f*cking thing off a cliff.
Old October 20th, 2006, 10:45 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Since they are all doing it, I'd look for common sources. I'd check for a bad connection in the positive lead maybe or a corroded/burned wire somewhere. You also may be dealing with a system-wide voltage fluctuation as well, which could be a loose belt on the alternator or the voltage regulator may be on the way out. Is the tach doing anything odd?
But the fuel gauge, it's probably going to keep doing that. Very, very few aftermarket gauges are dampened and the fluctuation you are seeing is the fuel splashing around in the tank.
My oil line fix
My 100k stopped odometer fix
Old October 20th, 2006, 10:55 PM
Did you get Visions? Mine dont behave that way at all.
Old October 20th, 2006, 11:15 PM
oldscratchggf
nate
95 d90
Yes, Visions.
The odd thing is that the tach (which is also VDO, but an older version) is perfectly steady.
Old October 22nd, 2006, 12:37 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
It Could Be A Ground To Body Problem As Well..
Legend in My Own Mind.
VDO Gauges mgrgpg For Sale - Parts 21 October 22nd, 2008 05:28 PM
FS: VDO Gauges, Switches, Brush Bar NASD90 For Sale - Parts 4 July 4th, 2006 06:35 AM
Source for VDO gauges loykd Defender Technical Discussions 4 February 23rd, 2005 08:08 AM
VDO speedo for sale vlocci For Sale - Parts 3 May 2nd, 2004 12:38 PM
Gauges mgrgpg Defender Technical Discussions 6 December 4th, 2003 12:15 PM
