New Turbo on Puma after only 30K - Defender Source
Old May 28th, 2015, 04:20 PM
Cayman Defender
Simon Watson
2009 Defender 110
Unhappy New Turbo on Puma after only 30K
My local garage has just told me that the bearings have gone on the turbo of my 2009 Puma and that I need a replacement - this is after only 30K. I have not heard of this being a common problem on these engines, has anyone else experienced this? Also, any suggestions on a reasonably priced replacement?
Old May 28th, 2015, 04:32 PM
This is primarily a US/Canadian based (No Puma trucks) group of LR owners. I'm sure you can get WAY better info from one of the UK Defender forums.
Good luck with your quest.
Old May 28th, 2015, 04:36 PM
Cayman Defender
Simon Watson
2009 Defender 110
Thanks, didn't realize the site was mainly North American. I guess being in the Caribbean my URL lead me to this site first.
Old May 28th, 2015, 04:41 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Originally Posted by javelinadave View Post
This is primarily a US/Canadian based """"No Puma trucks""""" group of LR owners. I'm sure you can get WAY better info from one of the UK Defender forums.
not a one
Old May 28th, 2015, 04:42 PM
Somebody here may still chime in with an answer but the UK site would probably be your best bet. Make sure you make an intro post there (UK site) or they go psycho on newbies. Why I don;t know.
------ Follow up post added May 28th, 2015 01:43 PM ------
Originally Posted by Z.G View Post
not a one
Old May 28th, 2015, 04:44 PM
Cayman Defender
Simon Watson
2009 Defender 110
Many thanks for the advice!
Old May 28th, 2015, 04:45 PM
Try here:
LR4x4 - The Land Rover Forum
and here:
Australian Land Rover Owners
Old May 28th, 2015, 04:52 PM
bjf's Avatar
bjf
barry f
94 ST #395
Roversnorth can get you the turbo
Cayman Defender
Simon Watson
2009 Defender 110
Thanks. Just tried Land Rover Zone, but will give your suggestions a go too.
Old May 28th, 2015, 04:58 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
It's about $1500, certainly not a common wear item at 30k
Old May 28th, 2015, 04:59 PM
Cayman Defender
Simon Watson
2009 Defender 110
Many thanks. I was thinking the same. I have seen problems with hoses coming loose on 2.2 TDCis but never the failure of the whole thing.
Old May 28th, 2015, 05:03 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
that includes you flying down to install it right
Old May 28th, 2015, 05:04 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
We can supply replacements however if the bearings are "going" and haven't gone to the point of damage the turbo can be rebuilt by a competent turbo shop. Or you can head over to the Ford dealer and order the turbo from a 140 Transit van...
Uncommon for the failure at that mileage - be certain to look after the oil feed/pressure to the turbo to ensure that the replacement doesn't do the same thing.
Old May 28th, 2015, 05:09 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Exactly....
Old May 28th, 2015, 05:24 PM
Cayman Defender
Simon Watson
2009 Defender 110
Many thanks. That is all very helpful. De
Old May 28th, 2015, 05:43 PM
tjfslaughter
thomas
Burbon
just make sure you use new lines and washers on the install!
Old May 28th, 2015, 05:50 PM
this and make sure you get an oil test. contaminated oil is a leading cause of premature turbo failure. trust me, I know. I would never replace a premature failure without conclusive evidence of what killed it, or you'll be doing it again in 30k or less.
coolant in oil will kill it very quickly. Get your coolant system pressure tested and your block compression tested too.
Mark Kellgren
KM4BOR
Old May 31st, 2015, 06:46 AM
Ohlins's Avatar
Ohlins
Retired Weirdo
1986 Army 110
As an aside completely,lots of short,starting and stopping journey's without letting the turbo rest at tick over for a short time can cause them to zap.
All the best
200tdi Ex British Army 110 Hardtop 139142kms
2.286 Petrol Series 3 Lightweight 75,043kms
3.2DiD Pajero 266,000kms
Yamaha XTZ660Z Ténéré 58112kms
Gas Gas 300EC Ohlins Enduro Moto.
Old May 31st, 2015, 10:27 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
What Ohlins said. The remedy for that, has traditionally been to add a timer that will keep the engine running for a few seconds (then shut it down automatically) after you turn the ignition off and exit the vehicle, allowing the oil in the turbo to cool down a bit.
The theory is that the oil is so hot, that it eventually damages the bearings in the turbo leading to premature failure. Allowing the engine to idle for a bit before shutting it down, circulates the oil and cools it enough to prevent that.
Thank you - Samer
1997 P38 Vitesse (Red)
2003 Discovery II
Defenderless, for now!
Old May 31st, 2015, 11:14 AM
Ohlins's Avatar
Ohlins
Retired Weirdo
1986 Army 110
That's right..I remember the first Td Mitsubishi Shoguns as they were called in Ulster(Pajero also known as) had a timer that allowed you to exit the vehicle after locking up,with the engine at tick over. Great idea.
I remember one of our new,with zero miles,work vehicles that was used on stop start drives had a new turbo replaced at 55,000miles due to no tick over ever being taken into consideration.
My turbo,from new,has lasted 525,000kms to date so far,allowing for a short spell on tick over each time.
NTO Puma Doors Right Side Only SafariHP The Vendors Loft 0 October 19th, 2013 05:29 PM
Turbo Diesel or Diesel Turbo? Paul K Misc. Chit-Chat 11 April 11th, 2013 11:59 PM
Won't start after after torrential downpour?! jijalicious Defender Technical Discussions 51 November 10th, 2011 12:17 PM
1997 Alpine White SW Offers over 30k... Eric Siepmann For Sale - Vehicles 7 November 3rd, 2004 01:52 PM
30K Service Question WCURoverD90 Defender Technical Discussions 7 April 17th, 2004 10:52 PM
