New to D90 with success to report - Defender Source
Old September 21st, 2011, 10:12 AM
red&yellowrovers's Avatar
red&yellowrovers
Joe Still
95 D90 NAS 3.9l ST AA Yellow #2719
New to me 95 NAS D90. Hard starting, erratic idle, dies at idle, dies coasting at low power, light spark knock right bank, hard to drive without "drive line buck" at low thtrottle settings. These items in "search" hit about a third of all time posts.
  • Presale PO had shop #1 install reman distributr, plugs, wires for starting problems. NO real improvment. Shop also reports blown head gasket. Renegotiated the purchase.
  • I had shop #2 repalce headgaskets- it was a known problem. "Surely will fix the starting problem". Still won't start or idle well.
  • I changed IAC and cleaned ecu contacts- some were really corroded. Little better here. Still spark knock though lite.
  • Next shop #3 deduced fuel pump weak based on pressure reading. I saw the rust on the bolts back there and told them to have at it. Told me if I ever had another vehicle just like it take it somewhere else- that perversly felt like good value.
  • Starts better but not quickly.
  • Lite sparknock worrisome so I get a modern new timing light for use. After having to buff the balancer to read marks I found the dist was turned so far the vac advance houseing hits the tstat housing, I mean really!?!? Needs to be pulled and resest with better adjustibliblty but it runs so well for the first time in 6 months its gonna stray this way for a while.
Now it starts first time and idles rock solid.
Conclusions, don't trust anyone to do the simplest items unless you verfiy behind them. The first guy put the distributor in wrong. The second guy did the headgaskets by marking the dist base and put it back the way he found it, wrong.
The third guy found fuel pressure and quite hunting.
"Driver be not mechanic thy self at own peril in the D90 world."
js
Old September 21st, 2011, 02:59 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Congrats on the "Rocket Science". Now set the timing to 10 BTDC, set the base idle to 500-550 with the stepper motor hose ports blocked off, and adjust the TPS to .033 volts and it will fire up and run beautifully!
Old September 21st, 2011, 03:26 PM
many mechanics are hacks, at least I know im a hack and when I fuck up I did it didnt cost me anything. I am glad you have sorted your issues.
Old September 21st, 2011, 06:32 PM
red&yellowrovers
Joe Still
Thanks guys! I'll have to try the advance tweak outlined.
I know it sounds uber-newbie but the biggest challenge I had was finding the angle for the timing light and line of site at same time. Thar be too many belts in thar!
90, d90
Multiple D90 Parts discojosh2000 For Sale - Parts 13 November 2nd, 2010 07:35 PM
1997, D90 50,000 miles or less JMPDIV82 Defender Technical Discussions 8 October 25th, 2005 10:34 PM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
